Dead easy, switched live, engine earth and signal to neg side of coil.Oh yeah, are the tachos easy to wire up?
Dead easy, switched live, engine earth and signal to neg side of coil.![]()
Also possibly illumination to pick up from lights, depending on 3 or 4 wires. Hope your tacho installation works better than mine didDead easy, switched live, engine earth and signal to neg side of coil.![]()
I got brave and went outside to put carbs back on after adjusting idle mixture,
Still doesn't idle, I've been gradually adjusting the mixture.......but still won't idle, I have the idle speed screw wound in, and still have to keep a but off throttle to keep it running, I have no idea of the revs yet as I'm still to attach tacho. Also is sounds very tappy (if that means something to someone)
Here a vid off it running, skip to 2:23 for how I have to get it started still.
Yes, I know I'm an idiot, and yes, I have made this a bit hard for myself, so hope someone can help
Thanks for any input![]()
"Also it's very tappy sounding from under rocker"
Thats sounds like valve clearances then neil. Did you not have this head stripped fully? Recheck rocker arms etc?
Tried pulling any ht leads off while its running to see if it makes any difference? I also think it sounds like its not running on all cylinders
Love the technical terms! Didn't leave a spanner in there did you??I made sure I put all valves back in same place, never touched the rockers, il have to get correct shimmy thing to check that![]()
Love the technical terms! Didn't leave a spanner in there did you??![]()
i set our kart tappets by adjusting the clearance down to zero, the back it off 2 flats of the nut neil (1/3rd of a turn) you could set yours like that for now![]()
Are all 4 carbs flowing correctly? Maybe leaning out on a couple of cylinders?![]()
Think we all would mateyYep, il add that to the list of things to check
I'd be screwed without this place!
Whats the worst that could happen??Worth a go ay?
by blowing down the overflows your effectively pressurising the float chambers and pushing fuel down the inlets. From playing with my carbs id say you have blocked pilot jets
mine where well blocked i ended up having to feed a single strand of copper wire ( copper is soft so wont enlarge the jets)down the jets to unblock them.
I shall have a go at that too.
The last set off carbs I stripped down, those jets (with flat head slot in) they were VERY tight in there, even snapped one if them.
Hope these are a littke more forgiving
I e been all over the cbr forum lookin for answers, not to keen to help tho with car builds
