Nice one on getting it running mateHow far away are you from getting it running with turbo?
With the wideband I bought the was a minimum distance for placement when used with a turbo. For the life of me I can't remember the measurent and the booklet has long gone.
paul (pollyp) discussed it in his blog iirc neil, his 1st sensor failed so he moved it further away i believe ?
i think it has an index mate ? or else pm him ehThanks, il have a look,
U wouldn't happen to have a page number, jus his blog is quite substantial, and a bit of a long read, very good tho.
i think it has an index mate ? or else pm him eh![]()
Stuff thisHere's the idea!
Beings I can only get the boost regulator down to 1-1.5 psi, I'm gunna try this
So normal driving, carbs fed by low pressure regulator at 0.5 psi.
As soon as the pressure switch senses ANY pressure from the turbo, it opens solenoid, allowing fuel from the boost fpr, which will rise accordingly with the boost pressure.
Hopefully this plan, along with the now lower pressure pump, will sort carbs flooding
looks a bit more complicated than my return pipe method mate![]()
Stuff this
Sent from my Galaxy Nexus using Tapatalk 2
it works just like a boost controller neil, you bleed off some of the pressure, so where the pipe enters the carbs you fit a T piece, and the return pipe has a #70 mainjet shoved inside to limit the flowWhere abouts would that pipe go on my set up mate? Tbh, I didn't really understand lol
Way to complicated for my likingHaha! Why's that
Looks like a home made bomb
Fair play this is turning into quite the build
not tempted to change to bike TB's?
the floats have only got a set buoyancy tho eh neil, if the needlevalve has,nt got a wear ring around it a rebuild kit wont help, try the return method (its worked for the past 5 yrs on our karts np)Right !!!
Still floods the carbs, even with 0.5psi
So it's got to be something wrong with the floats
Rebuild kits are £15 each and need 4
Carbs only cost me £30, and were pretty bad shape, so do I buy another set, or rebuild these?
nah, you reg it down to about 2 psi, and the return will damper that down.Been on couple of cbr forums, and it does sound like the floats ain't sealing right
I've got a couple of things to try to test, but gotta take carbs off
I thought about it, but the return line to the tank will be seeing higher pressure than what's going to the carbs after the regulator, due to electric pump
Tee off the carb feed neil (where its being reg,d @2psi) and run that return back to the tank, like a k11
just bench try it first ehI get the tee off part.
Do you mean run a separate return to the tank?
just bench try it first eh![]()
Right !!!
mine did the same no matter how much i altered the float levels. a full strip and bath in the ultrasonic cleaner sorted it out
Neither did I, maybe I was just lucky
Done it myself, I've got a ultrasonic cleaner.
ultrasonic cleaners are good for alsorts, we have them at work for cleaning injector parts, turbo feed and return pipes and allsorts of other things, they work really wellEither way, Gunna attempt sneaking out tomorrow and take carbs off for a look.....meant to be having Xmas family dinners and shiz
