that W/G seat is bad eh![]()
dremmel the seat the best you can i suppose mate, i think any repair will crack again personallyWot you reckon then? Sand blast it and weld it? Or chuck it?
it does,nt look like it needs a rebuild kit to me pork, just that shield if you can get one ? and that puck needs to make a good seal on the seat if you can ehHaha, I was just bout to right that!
Ok, il give it a go, get £50 rebuild kit, and see if I can get everything working together first, then maybe replace it or get another exhaust housing, like you said, before it turns into a money pit
i always grind seats upside down pork, if any of that stuff works its way down to the guides and it,ll smoke/drink oil forever, i find a length of rubber tube that fits snug on the stem, and use a drill on slow speed
its pretty bad eh ! its only gonna effect the boost levels tho ehI wouldn't risk using that housing if it was mine to be honest.
you could just weld it shut and fit an external screamer pipe porkmy TD05 just opens to fresh-air look
you,ll have a matt grey finish all around the seat and valve mate, get it near enough 100% coverage with the coarse, then finish off with the fine ehHow would i know when to stop grinding!
hehFlipping hell Franky! hahaha
i would rotate the tubby personally pork, and alleviate both problems![]()
it,ll move the hotside away from the spout tho eh, then shift the rad forwards maybe ?Thing is if I jus rotate it its still be in same place in front off radiator. Other option is to make a new mani
Daaaang!!!
Is this the first time you have tried welding?
Not at all. I am impressed. I would love to weld but haven't a clue. Maybe you have inspired me to just go get one and give it a go.
Are you using a mig? how did you find the learning curve. Think it is something anyone can learn??
Sorry for all the questions![]()
One of the best DIY work pork! What turbocharger have you installed?
I Hope everything will go as planned! Love your DOG!!!
