2015-07-15 Blyton Park Full Circuit
06:30 set off to blyton, but forgot my usb charger cable for the camera battery pack so had to drive back home and lose afew more minutes.
08:30 arrived at blyton in time. it drizzled slightly but the sun soon came out. signed in, unpacked, swapped tyres from T1R to the RSR and went for briefing.
09:36 sighting lap --------------------------------------------------------------------------------------------------------------------------------------------------------
Before:
Setup:
Dampers: 15/30 F/R
Tyres: 595RSR 2.0/2.55bar F/R Cold
Weight: 90% fuel, driver only
During:
Track Condition: dry
Brake Bias: 50/50% F/R
whilst waiting for the sighting lap, the car ahead had two drivers but cos one of em missed out the 1st sighting lap, the organiser asked if I could give a driver a ride on this remaining 2nd sighting lap while the other drivers in the other car, sure.
10:00 Run 1 --------------------------------------------------------------------------------------------------------------------------------------------------------
Before:
Setup:
Dampers: 15/30 F/R
Tyres: 595RSR 2.0/2.7bar F/R
During:
warmed up then went for the 1st run.
on a similar dry track last time at blyton, I recall that I had to use the cars inertia to help it turn through Port Froids at high speeds.
unfortunately today @08:32 whilst approaching the turn flat out, I switched direction wayy to aggressively, the body rolled alot and the stiff rear dampers & swaybar lifted the inner rear right up, the rapid inertia made the remaining rear right wheel lose grip and sent me spinning into oversteer.
while I sensed the car turning too much and screeching, thought "I know, I'd keep the throttle mashed and quickly power countersteer as usual" but to my surprise this didn't work
tried working the wheel to try regain grip but she just continued screeching in a long slomo spin, oh crap I'm outa control, best stop trying to power steer and hit the brakes now.
as I head left to the field, looking just beyond is tarmac and thought omg! I could smash into another incoming car!
thankfully that was the un-used empty Curva Grande corner and the gravel stopped me in time but almost had a brown moment.
front tyres are wearing outside the tread so the pressure's too soft.
be abit more gentle round that corner next time
10:25 Run 2 --------------------------------------------------------------------------------------------------------------------------------------------------------
Before:
Setup:
Dampers: 20/30 F/R
Weight: 85% fuel, driver only
During:
Track Feedback:
- rear suspension too stiff,
- lifting inner rear left wheel all the time,
- front tyres wearing outside the tread - front pressures too soft
- high speed oversteer at Port Froids
Track Times: (Gearing through Twickers, Jochen, Wiggler, Port Froids, Ushers, Twickers)
red lap times = traffic
lap 1 - 1:26 (2, 2, 3, 4 lifted, 3, 2)
lap 2 - 1:23 (2, 2, 3, 4 lifted, 2, 2) began to hear a high rpm hissing noise
lap 3 - 1:26 (2, 3, 2, 3 lifted, 3, 2) adjust 55/45% bias at bishops
lap 4 - 1:25 (2, 3, 2, 3 lifted, 2, 2)
lap 5 - 1:27 (2, 3, 3, 4 lifted, 2, 2)
lap 6 - 1:26 (2, 3, 2, 3 lifted, 2, 2) began left foot braking at bishop
lap 7 - 1:22 (2, 2, 2, 3 lifted, 2, 2) brake's upto temp at bishop
11:10 Run 3 --------------------------------------------------------------------------------------------------------------------------------------------------------
Before:
Setup:
Dampers: 20/30 F/R
Tyres: 595RSR 2.2/2.7bar F/R
Weight: 60% fuel, driver only
During:
Brake Bias: 55/45% F/R
increasing front tyre pressure to keep scrubbing within the tread and reduce oversteer
Track Feedback:
- still high speed oversteer at Port Froids
lap 1 - 1:22 (3, 3, 3, 4 lifted, 2, 2)
lap 2 - 1:21 (2, 2, 2, 4 lifted, 2, 2) brake's upto temp at bishop
the loud hissing noise sounded unusual, like a blowing boost pipe or blowing exhaust so I pitted to check for leaks but twas still producing boost ok
11:30 Run 4 --------------------------------------------------------------------------------------------------------------------------------------------------------
Before:
Setup:
Dampers: 20/20 F/R
Weight: 50% fuel, driver only
During:
Brake Bias: 60/40% F/R
couldn't find source of leaking noise
reduce rear dampers to reduce twitchy rear transitions
Track Feedback:
- slight high speed oversteer at Port Froids
lap 1 - 1:22 (3, 3, 2, 4 lifted, 3, 3)
lap 2 - 1:21 (3, 3, 3, 4 lifted, 3, 2) brake's upto temp at bishop
lap 3 - 1.20 (2, 3, 2, 4 WOT, 2, 2) slight oversteer at froid
lap 4 - 1:25 (2, 3, 2, 4 lifted, 3, 2)
lap 5 - 1:27 (2, 3, 3, 4 lifted, 3, 2)
lap 6 - 1:19 (2, 3, 2, 4 WOT, 3, 3)
it was near lunchtime so went out for lunch & fuel
