pollyp
Depends on cost, guessing it's £109 again? Not too bad if split with a mate, may well see you there
Will let you know
Installing some form of gauze/wire wool/ scouring pad will make a big difference to the amount of oil caught
Agreed!- Your welder is getting a good work out too....
Hey pollyp, I'm digging the daily updates aswell!
I noticed you have some issues keeping the exhaust gas temps at bay. You drive the car HARD on all the events you attend. Have you considered running race fuel, or running a water/methanol injection system? I did both on my build, making a homemade water injection system has got to be one the best thing I've built, and it cost me less than 80£
I'm only running post intercooler injection (175ml/min injector), but I plan to expand to pre-turbo injection. Cooling the combustion would make warped flanges history![]()
I'm 99% sure you don't run 3bars anymore?
What about a panel separating the glass into two chambers where the gas would flow in the top down to the bottom and then back up. More sirface area
3bar, crikey, that's a bit nuts.
I'm about to order some R888 or R888R for the turbo K11 depending on price.
45psi is madness, I run 32psi front usually and that is a bit high so will probably run 31 in the future.
Agreed the Micra is odd in liking high front pressures. Most FWD rally cars run 26psi cold all round, but the Micra runs well on 32psi (will adjust to 31psi) my Rover 200 (old rally car) ran 26psi fine all round.
The wheels looks ace in black Paul![]()
Yeezus...that's Hugh... That's hitting a good 42 odd when hot. Find the car skips a bit? What camber you running chum?I run 36psi all round on my T1Rs![]()
Clever ****er.I've designed it so the vapours swirl in a cyclone and spends as much time along the cold glass walls to condense before collecting via the middle in a free-flowing route with minimal risk of sucking the oil fluid out the outlet as it fills up over time.
View attachment 43180 View attachment 43183
if the ports just point straight in and we place a straight baffle between it like this
the gas simply flows briefly straight down & up and out the port with no time to fully condense and most of the flow misses out on the available cold surface, so it won't collect much vapour.
another issue is when the fluid level begins to rise beyond the lower lip of the baffle plate, it creates a restriction (require more pressure to push the fluid level down below the baffle plate before any gas can leak past) and a potential risk of sucking all the collected fluid out the port.
View attachment 43181 View attachment 43184
Glad its going well. Shame I like watching ur vidsjust came back from blyton, and saying in advance that it's been a big success n car working a treat BUT most of the stupid cabin camera footage has been corrupted so I've lost all but one clipgutted. still got footage from the pedals & suspension though. damn, woulda been good to see the awsome hot afternoon clips going flat out.
Used to run 34 on my old uniroyal rainsports was always fine.Yeezus...that's Hugh... That's hitting a good 42 odd when hot. Find the car skips a bit? What camber you running chum?
Well its all preference chap, suppose how often do they get warm enough.. Mine too tbh.Used to run 34 on my old uniroyal rainsports was always fine.
And the T1R responded well to 36 with full load so tested without weight and loved it even more.
Erm couldn't be too sure on camber bud need to get it tracked and lined up.
Yeah that's trueWell its all preference chap, suppose how often do they get warm enough.. Mine too tbh.
Ah I should have explained better, you don't pneed to insert some cooling holes through the heatshield so cooling air can flow into the bay but still shield the catchcan from infrared.
drilling lotsa holes would be very time consuming, wears out my drill bits and the holes will let infrared leak onto the catchcan.
instead a better easier option is to simply cut series of vertical slots across the plate (leaving the other half cos wanna fully shield behind the catchcan)
then bend them into louvres
so at one angle the air can flow through the vent
whilst at the other angle from the catchcans pov it's shielded from infrared
painted and installed
View attachment 43174 View attachment 43175
fitted the hub caps back on cos the weak plastic alloy wheel caps definately won't stay on under track heat
since it may rain tomorrow morning, rather than driving down on T1R then swap to 595RSR in the rain,
instead I just fit the Federals on now and simply drive down ready for the track.
Mmm she looks quite stealthy, need to paint the rears black too
View attachment 43176 View attachment 43179 View attachment 43177
it reminds me of the interceptor
went for a drive and with these evenly worn Federals the steering is now straight n true and doesn't drift to one side, so the cars alignment is very sensitive to tiny differences in tread depth.
another thing I noticed bout the engine tday is after a long coast downhill in gear (high vacuum & injectors off), when I reapply throttle and she resumes combustion, I see a poof of oily smoke behind.
I think the inlet stem seals are leaking, even though they're relatively fresh, could be another cause of leaking/pooling oil into the chambers.
the louvred heatshield has worked a treat. the engine bay & inlet pipe is cool again and the catchcan has remained chilled and condensing nicely.
tried stuffing the catchcan with stainless mesh, did it work?
nope the mesh simply restricted & distrupted the gas flow making it flow in the path of least resistance, straight from the inlet to the outlet, so only a tiny bit condensed on the bit of mesh it hit.
better to let the vapour flow freely over the entire chilled glass walls to condense fully.
ready for blyton park tomorrow![]()
Ah I should have explained better, you don't pack it.need to insert some cooling holes through the heatshield so cooling air can flow into the bay but still shield the catchcan from infrared.
Yeah that's true
Chewed through a front set of T1Rs in about a year rears are hardly worn so new front tyres laser line and new rear shocks for me I think.
Try and force open the file with vlc media player. Usually can play pieced\corrupted files
