I thought that... reminded me of spandex suits
And your point is?
They're in a pile on the floor. Will tidy them up once the dash is sorted etcElectrics all done then?
I'll give you a month to get it road worthy![]()
Same exhaus flange as mine, wonder where my td04 is in the td04 family, looks bigger than yours,
From my research the impreza/saab TD04 is the biggest one they didSame exhaus flange as mine, wonder where my td04 is in the td04 family, looks bigger than yours,
The 9 as far as I'm aware is only found in dieselsthe 9b is the baby of the TD04,s andy, about 1/3rd smaller than the other TD04,s
Make a carrier frame, bolt to underside with rubber washers.MaybelD
I chucked the oe one so I can't use it :/
It can't be fixed has to allow soo some movement
But I might just fix the lot![]()
I've got just thatMake a carrier frame, bolt to underside with rubber washers.
Found a picture of the area I'm around
Didn't say it was a recent photoNearly done?! My arse is it nearly done![]()
Plus the paneling isn't going on until last anyway so we can see how the prop turns etc and adjust mounts if necessary before sealing it away![]()
It'd have to be ballistic polycarbonate? So I dont get stones through the cabinPlease use clear acrylic instead of metal? Would be sooo cool
Cling Film would do no?It'd have to be ballistic polycarbonate? So I dont get stones through the cabin
Anyway I'm pretty sure I said to you its near mechanical completion? Which is around 30/40% of the entire project
Ah yea how could I forgetCling Film would do no?
Yeah probabaly did, oh well....Is it getting resprayed after it all?
Have I not shown you the plan?
I'll share it with you laterNot a proper one no, just talked bout it
Thanks folks
I feel better for sharing (almost make it sound like alcoholics anonymous)
It does look extremely narrow doesn't it... but if I show you this pic (requires neck tilting)Looks like it's coming along pretty quickly right now![]()
Aren't you going to have to have pretty thin bucket seats to fit in that gap now? Or its it bigger than it looks?
Changing gears going to the fun part. Its in the centre of a large boxy tunnel. Could skinny it up etc but I'm keeping it a simple square designCould be snug, doubt my lard ass seats would fit
Long, angled gearstick and short shifter.Changing gears going to the fun part. Its in the centre of a large boxy tunnel. Could skinny it up etc but I'm keeping it a simple square design![]()
Haha thanks Paul. It gets better but I'll do a load more, then update here. Its currently about 3 weeks behindwithout a hole amount of brown nosing Andy theres an awful lot of win going on here!
Im not sure if id shown you this before but its a different take on scoobyfrankensteining!
http://www.uphillracers.com/showthread.php/subareno-cliopreza-rs172-wrx-type-5647.html
Before I click on the link.. was this where the impreza floorplan was cut and rewelded into the clio shell?
I like your build it will be one off and a micra with 4wd and scooby sound it's defo one of the bestHaha thanks Paul. It gets better but I'll do a load more, then update here. Its currently about 3 weeks behind
There was a 106 with impreza engine and running gear in too on eBay a small while ago, but the engineering side of that one left very little to be desired. It was very err... flimsy? Chassis legs cut, no strengthening and it never ran surprisingly :/
It was definitely someone's first attempt at a project. Though if I'm wrong.. I dread to think how other projects ended up.
Aye it seems it mate.Thats the one mate, i think the fella has rather deep pockets!
O dear, sounds like it would fold like an accordion that 106!
Cheers AzzyI like your build it will be one off and a micra with 4wd and scooby sound it's defo one of the best
ThanksThat is freaking awesome...............
