Let's hope it goes like one tooHoping nissanubaru will end up looking a tad like a lancia integrale
I'm confident it will doLet's hope it goes like one too
Engine mounting frame
Yup my welder is boss
it's really stong weld by the looks or it is it stonger then tig would u say ?Yup my welder is boss
A weld is a weld so long as the penetration and the method is right then mig or tig or stick can produce good strong welds. Preference in my eyes. I can weld pretty much whatever I want with my mig (upto 10mm) so I'm happyit's really stong weld by the looks or it is it stonger then tig would u say ?
Meaning u can mig fuel rails ?A weld is a weld so long as the penetration and the method is right then mig or tig or stick can produce good strong welds. Preference in my eyes. I can weld pretty much whatever I want with my mig (upto 10mm) so I'm happy
Never needed to
I mean can mig work with fuel rails or will it burn ?Never needed to
Take it off the car first and it won't burn whatever you use
No I mean tig can burn holes on the rails and tig will work more better and softer without putting much heat on and won't pool as much ? Or am I wrong there ?Take it off the car first and it won't burn whatever you use
Question ^^
Any welder can burn holes it needs setting up properly for the thickness of materialNo I mean tig can burn holes on the rails and tig will work more better and softer without putting much heat on and won't pool as much ? Or am I wrong there ?
Like the mig is really strong and welds thick wire out and lowing the power don't work as I tryed last time that's why I sold it maybe have to get use to my tig and hope it works like a soft candle with a lower control on my rod filerAny welder can burn holes it needs setting up properly for the thickness of material
No idea what you mean about a tig being softer. Up to you how much you get pooling burn on a fuel rail you wouldn't hang around
Got to get used to your tools they won't do it for youLike the mig is really strong and welds thick wire out and lowing the power don't work as I tryed last time that's why I sold it maybe have to get use to my tig and hope it works like a soft candle with a lower control on my rod filer
Yh true say u got to show me tig how it's done are u local from meGot to get used to your tools they won't do it for you
I wana mig welder now just wana know if it's like tig ? And has the same input as both are same ? And weld all sorted of metal ?I'm a mig person. Never needed a tig so you'll have to ask another chap who can tig.. like @enuo
Tig is two handed, slow and requires patience but is very neat and gets good weldsI wana mig welder now just wana know if it's like tig ? And has the same input as both are same ? And weld all sorted of metal ?
right wat will do all a rounder ? Meaning any metal any tickness and to last a fair bit of time ? And cheaper to run? And parts and bits easy to get ?Tig is two handed, slow and requires patience but is very neat and gets good welds
Mig is just quicker and one handed
A mig wont weld aluminium without some fancy bits and bobs and fair whack of practice. A tig will with the right stuff. Its preference
can u tack and join with tig ?Mig is a better all rounder. Try tacking with TIG, can be a massive PITA conpared to MIG
Try here;
You can, but you need both hands to tack with TIG so you can't for example, hold a repair piece up to a sill and tack it, you have you find aome way of holding it there without your hands
I ain't saying nothingyou have to find some way of holding it there without your hands
Like a bossOh, three replies all at the same time..
Well that reply means you thought just as inappropriately as meThat's just inappropriate
Can I get a shock if I holded my work in place and touched with glove ?You can, but you need both hands to tack with TIG so you can't for example, hold a repair piece up to a sill and tack it, you have you find aome way of holding it there without your hands
You can't hold it in place as you will be using both hands to weldCan I get a shock if I holded my work in place and touched with glove ?
I'll need a clamp for work and 2You can't hold it in place as you will be using both hands to weld
Oh Alex
Walk into the fire
Feel the burn
And all that
I need to name one of my future projects
I've had nissan and subaru and created nissanubaru
This is a nissan and a nissan so such creativity can't be used
There's about 3/4 projects before this one so its gonna take a while being as each one I give a year for.
Micra (K10 of course)
Coupled with a Skyline GTS-T, GTR etc etc. So long as its the 2.5 turbo I'm happy
So I need a decent name
Nissanissan isn't allowed before we start
Micra GT-R is tad plain
K10 gtsI need to name one of my future projects
I thought that... reminded me of spandex suitsSkylicra?
Short sweet and to the pointMicra RB26 :L
Hmm... have to see if its availableh726?
