Thanks mate that's roughly sorted now with it mounted up. And the tunnel is alot prettier a job now its getting platedMade to measure that Andy! Nice work
Well the major work is almost complete. I'd say 70% ishLooking sweet as!!! Going to be a beast!!!
Just bodywork after that
It was a passing thought but it'll be fast enough to warrant a roll cage regardlessIt is coming along very nicely I must say, and the clearance!! Damn!! No room for error!!
Did you say your sticking a roll cage in this and using it as a hill climbing car?
@belly93 There you go Adam updated as promised
I'll get you those tunnel pics too. Get Christmas out the way and I'll get the tunnel finished first
Then you'll be helping me finish it off
Officially Year 2014
The year of Nissanubaru Micra WRX
Quite possibly one of the more outrageous cars I've built. But if I made it simple it'd be no fun
I've only been kicking about on here since last May. Though it feels like a lifetime. I look forward to sharing many more ridiculous projects with you
Me, H701 & Nissanubaru will all see you at JAE 2014
Magic powers my friendSo how are you planning on driving two cars?
Good for you. Doesn't qualify you to drive my 2I'll have a driving licence by then
That my friend is very trueIf you don't ask, you don't get
Height wise its got loads of room it'd look like spaghetti junction on top with pipeworkplenty of space man
Above yesabove and below?
There's not much but the crank oulley is in the way...ahh i see infront / behimd the rad?
Yup. Use poly air vents on tge rear windows and vents and fans at the rear cheap and easy to just a faffrear as in boot?
As far as I can tell the engine runs ok now just needs the usual bedding in process and a clutch. Gearbox needs a clutch fork pin toohow far is it of running??
What power will it run ?As far as I can tell the engine runs ok now just needs the usual bedding in process and a clutch. Gearbox needs a clutch fork pin too
But as far as getting in and driving it;
- I've got the fabrication of the rear to finish which shouldn't take long just a material thing
-Suspension turret built on the back and then bolt it all up
-Brakes plumbing
-Need wheels
-Final wiring (lights, horn, heater)
-A seat and a dashboard be nice too
After all that its cosmetic stuff
My target is 400-450 at the flywheel
That will be one off micra ? Is it Subaru or gtir engineMy target is 400-450 at the flywheel
Gti-r is nissan
Yeh I like the idea never seen one like itGti-r is nissan
Nissanubaru micra wrx
Suggests subaru eh
And yes its a one off
Now I said 80mm wider track each side
Oh how I was wrong... its 130mm wider each side. Super wide K10 yo
The fact I'll have a 80mm vent by the front door might give it awaySo gonna look like a 'sleeper' with huge ass arches like that
Shhhhh, we'll just say its the 12j et 0 rims he has
I'll be hiding it as much as possiblePaint the vent and mesh red? So it blends in a tad more?
As for stanced... never I'm not a scene kid with no imagination ta
Fair pointNo imagination? You thought about sticking a subaru inside a micra...
Genuinely considered it tooI think he should put the micra running gear onto the Scooby for lolz
