I have a piece of software that decodes the radio when you input the serial number..... (only works for BlauPunkt manufactured radios, serial number starts with 'BP')Hey John.
How do you figure these out?
As I said above, only works with BlauPunkt radios with the serial number starting with 'BP'............Serial Number: PP3001MB0062200
Part Number: 276-0034-5
Not the right numbers for me, please read some of the previous posts, possibly even the last couple in this thread.....Hi can I get a code please, serial number is 1012111 and device number is 7612830021
Hi, try 6936 or 0936.......Hi, can someone help me. I have a nissan micra K12 and don't know the radio security code.
The radio serial number is: BP538469511432
Part number : 7645384318
Thank you much it's workingTry 3460 or 1460....
Hi, try 8344 or 0344......Hi, can someone help me. I have a nissan micra K12 and don't know the radio security code.
The radio serial number is: BP334958126760
Part number : 8635123392
Hi thry 5415 or 1415...........Hi John,
Could you generate a code for me as well please?
SN: BP538962426632
7645389318
Thanks!
It worked! Thanks a bunchHi thry 5415 or 1415...........
Looks like it's going to cost you one way or another.Who said you needed a cape to be a hero? @John_D you're a bloody saint.
That being said, it looks like I'm in need of your help to. I've actually got one of those 2010 touchscreen radios, which has given me what appears to be a 7-digit serial number, and a 10 digit device number, 3135254 and 7612830023 respectively. Is that enough to work your wondrous magic? Thanks in advance!
Edit: ah, blaupunkt only. Shame. I don't suppose you'd know where I'd go to figure this out? I'm hopingi can do it without going to a dealer.
Hi, try 6448 or 0448..........Hi! I also need help with the code of the radio of my micra! Please
BP538575191702
7645385318
Not the right number, there should be 12 numbers after 'BP'.....Hi can you please help me get the radio code as nissan are asking for too much money that i dont have after i had to change my battery.
BP - 7612 830 001
Many thanks
This is the only numbers after the bp number its the touch screen radioNot the right number, there should be 12 numbers after 'BP'.....
K13 then? Sorry, can't decode them..This is the only numbers after the bp number its the touch screen radio
Hi Chris, try 6637 or 0637........Hi John you hero,
Hope you can help... BP538769670937
Cheers fella
Chris
Whats k13 sorryK13 then? Sorry, can't decode them..
Car Model number....Micra is K12 from 2003 to 2010, then K13 from 2010 to 2017.......Whats k13 sorry
The touchscren radios were fitted on K13 Micras from 2010, obviously fitted in Notes earlier.......... I cannot decode these radios....Hey its a Nissan Note not Micra sorry 2009
Hi, try 8236 or 0236........Hi any chance you could get me a code,
Serial number: BP334347323290
Hi, the serial number of the tadio is engraved on the side and/or the back of the unit. To find it you have to remove the radio. On the K12 this entails removing the whole centre panel, including the the two face air vents. In formation on how to do it can be found HERE, but if you are not reasonably mechanically proficient it would be better to get a garage or an auto electrician to do it for you. The number that I need to supply the code starts with 'BP' followed by twelve numbers...Hello everyone,
I bought my first car, which is Micra K12 3 days ago and I'm very glad I've found this forums. Unfortunately my radio also requires the code that was not provided by previous owner and I would be more than happy if you could help me too. But for the start, could you tell me how do I find the serial number that everyone is posting here?I'm just a girl with the first car, so please do not laugh and forgive my ignorance.
No problems , try 9187 or 1187....Sorry gave you the wrong code last time, the correct serial number isn't actually BP334947323290
Hi, try 5353 or 1353....Hi,
I just bought a Nissan Micra and today I replaced the battery, I realised I have no code for the stereo
Please can you help me having the code.
Stereo number is BP334936372855
Thank you very much!
Hi, try 9966 or 1966......Hi,
We have replaced out battery and mooier everywhere butunfortunately we have no radio code.
Can you help us?
The serial nummer is: BP538471216244.
Thnx!
Hi! It's not working though :/Hi, try 6448 or 0448..........
Just double checked the serial number that you supplied and those are the correct codes. After you input the code are you pressing the correct button to accept it? (usually T/A or scan up)Hi! It's not working though :/
Sadly no, my software will not decode the sat.nav units with the BP number starting with three zerosPlease, could you get the pin?
BP0003 9 5299614
7612830003
I had 3971 and 1971 from friend but didn't work =[
Would you have any idea how I can get these?Sadly no, my software will not decode the sat.nav units with the BP number starting with three zeros![]()
