Hi, try 7382 or 1382....Hello,
I have the same problem as you. I bought a Micra, but unfortunately do not know the radio code.
Can someone please help me get it, the radio is Blaupunkt BP536158186807.
Thanks in advance
Thanks in advance
Hi Adam try 5975 or 1975....Hi John
Please could you help me with my radio code. The code in the owners manual is wrong. I have an 07 sr160 and the radio number is-
BP5387 7 1226267
many thanks
Adam
Hi, they are not known as 'Main Stealers' for nothingHello,
just bought a used 2003 Nissan Micra and the battery went flat, the radio isn’t working anymoreThis is the serial number:
Blaupunkt-Werke-GMBH
BP334936354680
I called Nissan but they want 45 quid for the code... can you please send me the code for this!
Many thanks
M
Hello John, the code is correct and the radio works now. Many many thanks for your helpHi, try 7382 or 1382....
It worked!! Thank you so so much for your helpHi, they are not known as 'Main Stealers' for nothing...... Try 7365 or 1365.....
Thank you John. You are a legendHi Adam try 5975 or 1975....
Hi Minna, only one possible for this 0022.......Hello, I have the same problem with the radio. =( Could you please help me?
BP5384 7 1207304
Thank you!
-Minna
Hi John,
Had to disconnect the battery, so got the radiocode card out for use a day or so later. It disappeared, I think my wife binned it not knowing what it was. Could you please help with the code for radio serial number BP536556442105 ?
Mike
Hi Mike, looks like you need either 6264 or 0264, write down the appropriate one in several places , with at least one in a place that your wife doesn't 'tidy up'.......Hi John,
Mike
Hi, try 4151 or 0151...........Hi John,
Looks like I've got a common problem here... dead battery due to car not being used during lockdown and then not having the radio code!
Could you please provide me a code for Blaupunkt S/N: BP334947240941 if possible?
Thanks a lot!
Cheers John. Battery has died again ? so will try it after a recharge. Appreciate itHi, try 4151 or 0151...........
4151 worked a treat. Thanks a lot!Hi, try 4151 or 0151...........
Try 5202 or 1202.....
Hi, try 7033 or 1033....Just purchased my Micra... like many others no radio code. Could someone help?
BP 234732035536
Many thanks!
That's got to be a first!!Dealer sorted free of charge
BP375758484285 serial numberHi I need the radio code for my nissan micra 53 plate 5 door car
Ah the all important bit added to this post......Try 3504 or 1504.......BP375758484285 serial number
The software I have only decodes BlauPunkt...... Other software is out there but I don't have it.....Why is it you can only get the codes from the blaupunkt radios ?
Don't recognise that numbering format. Where did you find those numbers?hey i need help lose radio code for my micra k12 2006 my serial number is BP7-s-VA 2892-0121213-19 BA02 8166 Model:NISSAN MMR CD-G
BP538458814349Don't recognise that numbering format. Where did you find those numbers?
Now that's betterBP538458814349
Hi Andy, try 7389 or 1389........Hi John
Hope you can help me please
I have a 2003 Nissan Micra and there is no manual inside the glove box, so I can't get the radio code after change of battery. can you help me please.
The Radio Serial is BP334936368082
MM CD-K
7643349318
Thank you very much for your help
Andy
Hi, for much better tunes, try 6594 or 0594........Hello John and all,
I would appreciate some help with radio unlock after general service and battery switch. I'm really tired of listening to my sister's hip hop super duper mega hits from her cell phone.
God please return me my CD collection of power metal back ...
BP234756422053
