Tis an awesome bit of kitI want a lathe!!!!!
Please tell me you are not joining the mscs carbon fibre wrap everything brigade...
Carbon!!!
They're ladies tights, he's gunna put them over his lights to make them look tinted, getto stylee
Top and tail a fork and spoon.... SPORKI need to get my welder out and weld something....anything!
Sent from my HTC One S using Tapatalk 4 Beta
Finished my tie bars... finally
My lathe is clearly old and tired and wanted new bits here and there. So now its like new I cracked on
Finished my bushes in the same was as the first set
Made stainless steel inserts
And constructed em all
Ruined the paint by not letting it dry and touching it with polyurethane fingers
So resprayed em
Oh and those polyurethane fingers made this
Poly bushed engine mount
Still half a day to go too
I suppose I better start making a set ehwheres mine?
Nope but you have to redo em all if your doing ityou plumbing in all 4 brakes to the handbrake?
could you not plumb the master into the h/b yhen h/b into the splitter?Nope but you have to redo em all if your doing it
You need a feed from the master cylinder which on a k10 goes into a splitter. Cant do that without a twin cylinder hydro... which doesnt fit
Afraid not. As they split opposite.could you not plumb the master into the h/b yhen h/b into the splitter?
They're linked front right/rear left and front left/ rear right so they'll split wrong
So you've got to run one of your lines from your cylinder through the hydro thrn split it for the rear
See @enuo we are going to have to sort another harness bolt on the tunnel. The k11 seat belt lock is on the seat rail.For our @SirChris
