h701micra
Deactivated Account
Correctplanning dry sump?
Plus a potential rear mounted turbo. Just looking into gas flow etc with different turbos
I have 4 options
TD04
VF34
GT28R
And the mahoosive GT45
Might need to be to supply the air required to maintain pressure at that distancebiggest possible
More thinky before doless thinky more do lol
I got there in the endThat was silly
NissanubaruH701 or nissanubaru?
I can teach you to weld... but I'm not giving welders outTeach me to weld.... And give me a welder...
Mines only 4mm as that's all my regs requireis the 5mm sheet expensive Andy or not too bad?
My other investment
Ultrasonic cleaner, should see some good use over the next few weeks
It'll clean anything
Giving out more than LiptonOoh eeer corporal haha
Shall doBefore and after of a piston please mate
Shall do mate@h701micra if you comes across anyone doing a k11 poly screen let me know mate
I'll have a full comparison log to share once I get em all inHave you been measuring the weight difference between glass and plastic, it would be good to see if the cost was worth it.
Already haveGood excuse as any to go poly I guess
What's the betting you'll get one smartarse telling you you can't have a poly screen for the MOT
I'll say simply, Micra Challenge Cup preparationWhat's that going on :O
Ended in 2011?I'll say simply, Micra Challenge Cup preparation
You're thinking Micra ChallengeEnded in 2011?
Can't tell you, starlet boyEnded in 2011?
Got a question for the knowledgeable turbo folk for an opinion on twin turbo compound charging of sorts
Photos on the Internet suggest the exhaust blowing through one turbo, out said turbo and into the other in a traditional manner
And having turbo ones compressor blow into the inlet of the 2nd
But what I've thought is
Could you use all the exhaust pressure on one smaller turbo and instead use the compressors boosted air to spool the 2nd?
Not quite compound charging then I know but here's the advantages I can see
It'd spool the second turbo quicker
It'd spool cooler too
Any thoughts? Is boosted air through the turbine even a good idea in the first place?
