So what your saying is a stock ga16 flywheel will fit bolt pattern wise and would technically fit inside the cg box? It's the same spacing as a cg13 fly?
In that case the friction plate would fit inside and clutch plate bolts to original flywheel holes
Basically the whole kit would fit, are the splines the same or different for the cg13 gearbox and ga16?
Would be awesome if we could get a decent ga16 setup to fit?
i doubt if you will bust a g/box martin, just fit the GA f/w and clutch eh (james did a guide iirc)
I tested it today, Fidenza GA16 flywheel fits CG crank, and the clutch disc spline fits CG gearbox, so its plug and play.
The only difference is where the flywheel ring sits, because of different dishes, but nothing special, from the block lip to ring there are 30mm on the stock flywheel, and 27mm on the fidenza flywheel, 3mm different, but the starter motor will engage on the flywheel anyway...
i binned the tin/sheet metal sandwich plate on my engines, so my starter is about 2mm further in eh (and it still meshes ok)
Hey baguete, so what your saying is then that it will all work:
1.6 clutch, pressure plate and flywheel along with the cg13 gearbox?
do you have pics of this, if not please do get it on your blog, im interested to see
Yes, it can work, i have to put them on the car really, but as far as i can see, all is plug and play, if the flywheel fits the crank and the clutch disc fits the gearbox, it should be fine.
I tried to take some pics today, but i ran out of battery, will take some tomorrow...
was just reading through the link frank posted, so would this set up still work with a standard GA16 fly, as the fidanza is slimmer/lighter giving that extra few mm so the gearbox can enter the clutch plate. Or would a standard fly also need to be lightened?
Awesome!! So is a stock clutch setup possible? Or just the setup you have? Also what's the rating of your clutch matey?
I have a XTD Stage 4 Clutch, dont know how much torque it can handle, but maybe 300Nm? Frank, what were the power figures of Dale's Almera turbo?
i think it was about 230 hp mate![]()
And torque figures mate, do you remember? I think the clutches are rated about the torque they handle, right? :wasntme:
Its capable of 297ft/lbs/ and 390 bhp
How different is the cg fly to ga? Also is ga fly solid like cg so could be lightened? Thankyou for very informative posting
I appreciate it mate
Bit to over kill for me then ha ha
I reckon an uprated standard clutch would prob be ok, can anyone remember kristains torque figures? Or stanis by the if chance? Chears
The XTD clutch i have as those specifications?
Looks at the torque rating of that
http://www.dragtimes.com/parts/BBP-...RA-200SX-NX-16L-GA16DE-DOHC_360290863187.html
Scopez that's even enough for your torque at the grand price of 30 quid with shipping and tax lol
If it works then perfect![]()
..might be of some use for you![]()
Hopefully mate!! Damn site cheaper eh!?
Could have your clutch cams and remap alot quicker than you think
If yours measures 200mm let's hope baguetes is they same in every way
Could you have a look at the spine please tristan? Take some measurements and someone else can do with the 1.3 clutch
What clutch wil you go for if it all fits?
Won't you be needing it bro or you going for fidanza?
Or this
http://cgi.ebay.com/ebaymotors/ws/e..._nkw=140277260272&_fvi=1&_rdc=1#ht_3909wt_948
Could prob get fly on it's own thou![]()
