Bad luck mate, have you managed to get a new bumper support?
Erm, Ahmed I think you need that. If not have you blocked off the nozzle on the radiator.
Good news Manny![]()
The bumper has been resprayed?
Tough a phase 1 grill looks better imho !
Seb
why do you need it for phil? i havent blocked the nozzle dont want the radiator to blow lol. frank said its ok to take it off hes also taken his off. ive just let the pipe connecting to the radiator dangle down.
overflow tank is there cos coolant expands when hot and contracts when cold and the tank captures this surplus so that no air gets in the system.
if you've disconnected the pipe left exposed without any reservoir for the surplus, then when the engine heats up the coolant expands and just spews out the pipe.
when the engines off n cooling down, the coolant strinks which causes air to be sucked into the short exposed pipe and into the engine.
when you next start the engine, the reduced amount of coolant and air just churns through the system with reduced cooling efficiency and the cycle repeats till enough coolant spills out the pipe that the engine starts to overheat
I mean "a phase 1 rectangular grill would look better than the rounded shape phase 2 grill" Manny:redface:
Yep that what I mean Mannybut I do believe they also released SR with phase 2 grill + driving lights bumper since 1996.
January 98 yes !
