The should come on on FULL beam only. Not side, or dip beam just full beam.
if it comes on with anything other than main beam, then yes. As long as you only switch them on when on main beam then thats fine, but it will be a pain in the arse switching them on and off at the same time as main beam.
no you just need to wire the trigger wire to main beam instead of dip like you do now.
You did, that wire does the same job on the battery side, that's why I was a bit confused last week why you have the cable going to that side.
Dip/Dim has nothing to do with it. It should be wired like this:
With or without the switch, it doesnt really matter.
I understand it and that's how it's currently wired, works fine when the ignition is off, but as soon as the ignition is on and the car is running it no longers works the same which is very confusing, I had the same setup on my K11 facelift but with angel eyes and no problems.
MM, it worked, lol. that box must put a small voltage through the dip amd main beam circuit. Thank God that worked though I would be pulling my hair out if it didn't, lol.
Get a super s toy eye aswell, its only 3 bolts.
Very Nice Ahmed, will you be painting Red before Putting on? Will you also be needing a Hand?
I might be free Monday, but I don't know what plans I have for this long weekend. I'll bring home some Label Remover to get that double sided tape stuff off, hoping it is double sided tape and not TIGER SEAL, lol.
wooohooo you got that on fast they make such a big difference nice work
that wont look too bad if you fit a new support/pod and rework the chassis end manny![]()
if got the support pod sorted out but what if the bumper has moulded into the shape? its been squashed, any solution to this. will it spring back out?
