Hi try 4115 or 0115....Hi just bought a new car Nissan micra
2003 stock radio.
Details are:
Blaupunkt made in Portugal
BP334936345189
7643349318
any help will be appreciated !
2003 stock radio.
Details are:
BP334936345189
7643349318
thanks 4115 did the trickHi try 4115 or 0115....
Hi, try 3223 or 1223.....Hi John
Any chance of the radio code for BP334958140606
7643349318
any help would be grateful!
Hi, 1298 would appear to be the code that you need......HI.
Can someone supply a radio code please
Serial. BP538469466474
8 635 123 392.0
66670008671 NISSAN MMR CD-G
Thanks in advance
Not one that I can decode I'm afraidHi John,
Am i able to get a radio code for the serial number: PP3001MB 0005906
part number: 28185 BG10A
Model number: PP-3001M
Thank you.
Thank you so much. My partner is over the moon the radio is working.Hi, 1298 would appear to be the code that you need......
Hi, try 9330 or 1330.....Hi John,would you be able to help me with code please for my Nissan Micra..
BP234720499646
7642347318
Tnx
Hi, 7552 should work, but if that fails 1552....Can You also help me with the code?
BP334936396649
8 635 123 392 (or 393, unfortunately no card)
Thanks!
Yep, first one works just fine. Thx!Hi, 7552 should work, but if that fails 1552....
The best bet is to Google 'Nissan Micra Radio Removal video' and pick the video guide that is the same as your car/radio model...........Hi, how can I get my serial number and product code? Not sure how to remove the nissan radio system
Thanks for your reply, I'll have a look! My car is actually the 2004 model, not 2014, I must have mistyped.The best bet is to Google 'Nissan Micra Radio Removal video' and pick the video guide that is the same as your car/radio model...........
Just realised from your profile that you have a K13, the video guide you probably need is THIS ONE , the bad news is that my decoding software may not work on K13 radios, I know it doesn't on the SatNav ones.....
That makes things easier, the number I need to decode the radio is the serial number, starting with 'BP' followed by twelve numbers. You will find it engraved on the back and/or side of the radio when you get it out...........Thanks for your reply, I'll have a look! My car is actually the 2004 model, not 2014, I must have mistyped.
Hi, 4103 or 0103 should put you back in her good books :0)Hi,
Could you help me to find the code for this radio? My wife is driving me crazy
BP3349 5 8126503
7 643 349 318
Thanks!
Got the serial number now:That makes things easier, the number I need to decode the radio is the serial number, starting with 'BP' followed by twelve numbers. You will find it engraved on the back and/or side of the radio when you get it out...........
Hi, try 7298 should work but if that fails try1298....../Got the serial number now:
BP3349 4 7308389
7 643 349 318
Hope this is okay!
First one worked, thank you!!Hi, try 7298 should work but if that fails try1298....../
Thank you! It worked like a charmHi, 4103 or 0103 should put you back in her good books :0)
Hi I am new to the site, not even sure how to post a message so just hooked on the back of someone else's, hope that's ok. Is their any chance you could give me a radio code for a Nissan Micra 2005 the radio serial number is BP334958142043
Its my daughters 1st car, when it was serviced we lost the radio. Any help would be appreciated.
Kindest Regards Carl
Brilliant thank you so much John D you are a life saver, it worked 1st time. You can't come and tune it in for me can you lol its the strangest system I've come across for a car radio.Hi Carl, best way to get a code is to join one of the several code request threads on here, that are already running, so yes you are in the right place, far better than starting yet another new thread on the subject.
The number that you need is 0113...........
Hi, the code is either 6302 or 0302.....Hi, I just bought a micra 2003 today but the previous owner didn't tell the dealer the code so i have no idea what it is.
The serial number is: BP234632516819
The part number is: 7642346318
I would be very thankful for any help
Hi Mark, try 7392 or 1392.....Hi, desperately need a code for a 2003 micra fitted a new battery but can't find the code for the radio anywhere,
serial number BP234631997777
7642346318
Many thanks in advance Mark
excellent, many thanks worked straightawayHi Mark, try 7392 or 1392.....
Hi, no not a Clarion but a Blau Punkt, which means that you are lucky and I can get the code for you, which is 0321........Good nigth, can someone help with my code? the serial number is: BP536258450695 ... I think this is a clarion radio, I appreciate your help.
Hi try 8382 or 0382Hello,
Kindly ask you the radio code for my Micra:
- BP738376738453
- 7647383318
Thank you much!
Nicolas
Sorry don't recognise any of those numbers, doesn't look, from those, that it is a BlauPunkt unit that I can decode.....Hello i looking for code for my radio
Device number: 7612830022
Serial number : 3040714
Bosch part No : 7 612 830 022Sorry don't recognise any of those numbers, doesn't look, from those, that it is a BlauPunkt unit that I can decode.....
As I said above I can only decode BlauPunkt manufactured radios.......Bosch part No : 7 612 830 022
Nissan part No : 25915BH10C
If that's help
Hi try 8382 or 0382
Hi try 7348 or 1348I would appreciate it if i could get a code for this.
BP538369454173
7645383318
Thank you very much
