Hi, try 3998, or 1998Can someone help me with a code?
Blaupunkt Nissan MMRCD-G
BP 538971333974
7654389318
Thanks in advance for your help![]()
Sorry, John!Brilliant, worked first time. Much appreciated. You're a top man Jihn
Your unlock code is 1211, write it down and keep it somewhere safeHello Guys,
My Micra was in service, they disconnected battery and now radio needs code.
I don't have card with code, it's lost somewhere.
Can anybody help me?
SN: BP7383 8 7796084
PN: 7 647 383 318
I would really appreciate if you Guys can help me!
Getting busy todayCan someone pretty please give me the radio code for BP334958131959. Thank you
Thanks John! I see you helping everyone. Really appreciate it, will try and let you know how it goesGetting busy todaytry 9656 or if that doesn't work 1656
Thank you so much! I have question if you can answer me, how do you get code?Your unlock code is 1211, write it down and keep it somewhere safe![]()
Hi, try 5568 or if that fails 1568....Hi would you be able to help me with code please for my Nissan Micra
Serial no: BP234732017908
Well that's a new one on me, never seen a 'BP' code starting with three zeros before.Can someone help me with a code for my Nissan?
Blaupunkt Nissan LCN
BP0003 9 4685526
7 612 830 003
Well that's a new one on me, never seen a 'BP' code starting with three zeros before.However the software recognises it and comes up with the codes 5762 and 1762.....
The code is correct for the numbers that you supplied, suggest that your serial number is 'incorrect', how did you obtain it? You can only get the correct number by removing the radio from the dash and reading off the engraved number, starting with 'BP' , on the side or back of the unit......Thank you for help but the code is incorrect...![]()
Just run those numbers through again and get the same codes. How are you inputting the code and what results do you get?Numbers on top of the radio:
BP - Nr. 7 612 830 003
Nissan part no. 25915BH00D
Numbers on the side:
Blaupunkt Made in Portugal BP0003 9 4685526
Nissan LCN 7 612 830 003
e1 03 5454
When turned on, the radio requests the code. As I enter 5762 or 1762, it is displayed that it is incorrect.Just run those numbers through again and get the same codes. How are you inputting the code and what results do you get?
Looks like my software doesn't work on the much later Blaupunkt SatNav models....Just found this on the net and my software doesn't come up with the right code for that either.......
Looks like a Nissan main dealer might be your best bet?When turned on, the radio requests the code. As I enter 5762 or 1762, it is displayed that it is incorrect.
Hi, try 8978 or 0978....Hello
I have a 2005 nissan micra 1.4 SVE and had to change the battery recently - and now the radio/cd player is asking for a code. I don't have a code. It is a factory fitted radio/cd player. The number I have found is BP536556021495 but not sure if this is the serial number. Another number on the radio unit says 59730002536.
Hope someone can help me with the radio code to put in please?
Hi, try 9574 or 1574.....Hi guys i changed the battery to my micra and I don't have the code
BP538865050568
7645388318
Made in Portugal
Thanks in advance
9574 worked thank youHi, try 9574 or 1574.....
Hi Try 8085 or 0085...Hi! I disconnected my battery and I don’t have a code. I have the serial number of my radio: BP234631957276. Can you help me, please?
Kind regards!
Hi, try 7475 or 1475......Hi John,
Any chance of the code for BP5384 6 947261 3 on a Micra C+C?
Thank you sooo much!!Hi Try 8085 or 0085...
7475 worked a treat. Many thanks.Hi, try 7475 or 1475......
Hi Peter, try 7728 or 1728.....Hi John,
Any chance of the code for BP5384 6 9480442.
Thanks John,Hi Peter, try 7728 or 1728.....
Hi, the code that you need appears to be 1085....Hi could anyone help me I've brought a nissan micra but I don't have the radio code
Bp334947225411
7643349318
Thanks in advance
Brilliant thankyou ill give it a bash once I can get the wait 1 hour off the screen I'll keep you posted thanks againHi, the code that you need appears to be 1085....
Thank you very much for helping me very much appreciate it the code worked thanks againHi, the code that you need appears to be 1085....
Hi try 2076 or 0076I need of the radio unlock code for my micra
The details are:
BP538761129240
Nisan no: 7645387318
024199
Thanks!
Thanks a lot ! ????Hi try 2076 or 0076
Hi, try 5656 or 1656....Hi,
Radio reset after changing clutch on Micra. Missing code in the manual.
Any help with a code much appreciated.
BP538471204524
7645384319
Thanks.
