Code sent in reply to your other post........hello all......
Im new here and Im want your help...
pls help me.... my radio is locked...
nissan MMR CD-G
7 645 389 318
BP5389 6 9260317
plsssssssss...........
nissan MMR CD-G
7 645 389 318
BP5389 6 9260317
Serial number of the unit, starting with 'BP' then 12 numbers is required to work out the code.......[QUOTE = "John_D, posta: 770298, üye: 27688"] Diğer gönderilerinize cevap olarak geliyor kod ........ [/ QUOTE]
2005 micra visia radio code please
4 haneli kilit açma kodunu çözmek için 'BP' ve ardından 12 haneden başlayarak seri numarasına ihtiyacım var ....[QUOTE = "John_D, post: 770814, üye: 27688"] Birimin seri numarası, 'BP' ile başlıyor, daha sonra kodun çalışması için 12 sayı gerekiyor. [/ QUOTE]
4 rakam soruyor
Nasıl bulabilirim o kodu
Hi, try 6937 or 0937..........Hey, Happy new year.
i need help with nissan micra k12 radio code
Nissan MMR#2 CD-G
BP738387804988
7647383318
thanks )))Hi, try 6937 or 0937..........
Hi, try 4378 or 0378.....Hi, I wonder if you can help. I bought a micra sport a few months back. I had to change the battery recently and the key code in the book is wrong. I suspect it is not the original book. I hope I have the numbers you require. Thanks in advance. Andy.
BP538771223210
7645387318
You are a gentleman and a scholar sir. It's perfect. Thank you so much.Hi, try 4378 or 0378.....
No problems, try 4950 or 0950.....Hi .
Please help me with audio/radio code:
Bp234632508026 ,7642346318
Thanks !
No problems Stuart, try 6013 or 0013.......Could you possibly let me know the code for my Nissan Micra radio.
The serial numbers are BP538469505864 and 7645384318.
Many Thanks
No problem , it would appear that the code that you need is 0092..........Hi. Can anyone help with a cd player code for BP234746064541/7642347318 pls?
Hi, the unlock code that you need appears to be 1733..........Hi could anyone possibly help me with radio code before I lose will to live?!
Is Nissan Micra MMR#2 CDG
BP738387800798
7647383318
Thanks in advance!
Hi, try 6150 or 0150..........Hi
unfortunately I have the same problem as everyone here.
.. needed to change the battery and now my car is asking for this radio code.
My car is Nissan Micra MMR#2 CD-G
BP738398857071
7647383318
Would be so great if anyone could help me out!!
Thanks in advance!
Hi, try 7406 or 1406.......Can I please request code for Nissan Micra 2005
Serial no BP538854889043
Well you have read just enough to find your way here and to ask us what you want. Now read a bit more and come up with what we need from you to enable us to give you a code.......Hi would somebody be help me, I recently had my clutch done and the radio is asking me to enter a code , I have to wait a hour but can somebody tell me my code .
I have a Nissan Micra sr 2005 and I don't have the card
Many thanks it worked mate straightawayHi, try 7406 or 1406.......
You have left out a digit from the 'BP' number, there should be four numbers between 'BP' and the letter 'A', not three.....Hi, I'd really appreciate some help. Disconnected the Blaupunkt radio thinking my old adaptor cables would work in my new car - they didn't fit! Anyway, I need to use the old radio again and have no code.
The serial number is BP783A9257703
There's another code: 7647383318
Thanks so much in advance!
No worries, try 7400 or 1400 (probably both will work)..........Hi John,
Absolutely right, sorry. It's BP7383A9257703...
Many thanks.
Hi, try 4487 or 0487....Hi, can you please check the radio code for 7 654 383 318, s/n BP538369457204? Would be greatly appreciated
Thanks, will try that laterHi, try 4487 or 0487....
Hi try 1812 or 9812..........if the first one works at least it will be easy to rememberHi ,
Just replaced my battery,and i need radio code pls
radio number is: BP5387 6 9678235
