Hey John D,
Struggling to sort a code out any help would be much appreciated ...
Nissan MM CD-K (BLK)
55610057202
BP334947230576
Thanks !
PLEASE SOMEBODY HELP
Hey John D,
55610057202
BP334947230576
Thanks !
Hi, try 7938, or if that fails 1938Hey All,
55610057202
BP334947230576
Try 4620 or if that fails 0620Hi! Could anyone help me with the code, would be great
BP334947262602
7643349318
Try 6816 or if that doesn't work 0816Hi, if anyone could help I would be very grateful. My wife's Micra battery has gone dead and now the radio needs a code.
The details from the radio are;
BP234631999269
Nissan MM CD-K
7642346318
Try 3139 or if that fails 1139Hi, friends. Can you help me? I have replaced my battery and now I need a code for my Micra.
Here are details
Blaupunkt Werke
BP 3349 3 6384311
Nissan MM CD-K
7643349318.
Sorry don't recognise any of those numbersHey, my radio has always asked for a code, I pulled off the front today and found the following codes:
66670023478 Nissan MMR CD-G
BP7-VA2892-016525223 AV01 8241
Can anyone help me? Thanks
Another 'Clarion' radio, sorry not got decoding software for that make, I can only supply codes for 'Blau Punkt' ones. Not sure if anyone else on here can help.Can somebody help me with my car radio code please?
Serial number is
CL052920071067
Part number is 286 9881 02
Thank you in advance
Marek
Another 'Clarion' radio, sorry not got decoding software for that make, I can only supply codes for 'Blau Punkt' ones. Not sure if anyone else on here can help.![]()
Hi Nathan, try 3685 or if that fails 1685...Hi my radio has lost the code I've removed the radio and there's a piece of card with these numbers on, 28 184 BC41A and ZH-912 are any of these the unlock code?
If not here's the others BP538761139239
7645387318
Can anyone help?
Cheers Nathan
Hi, try 2847 or if that doesn't work 0847HELLO I NEED RADIO/CD PLAYER CODE
BP536158183001
NİSSAN MMR CD-S
7645361318
THANKS FOR YOUR HELP
Try 6924 or if that fails 0924Hi all.
Could anyone help me out as my battery died and I have no code for my radio.
Any help would be greatly appreciate, thanks in advance
BP334958138269 serial number
28185AX613 HP3123 part number
Thanks a million for that, life saver... a gent worked a treatTry 6924 or if that fails 0924
hiTry 6924 or if that fails 0924
Not sure if any one else on here can help, but I can only supply codes fro Blau Punkt ones....Hi. Hoping someone can help me to get a code for my Bosch radio on Nissan Micra. Details are:-
Serial number: 9588409
Device number: 7612830031
Date: 10.08.26
Thanks in advance.
Hi guys, so tried the codes and they won't work. The way I put it in was hit the numbers until i reached the right sequence and then hit the ^ button. Is this maybe the wrong thing to do? As it always says to wait 1h. Also, i've learned that if i leave the radio on and switch off the engine, the next morning the radio goes straight to snter the code, maybe it will help somebody. Thank you kindlyHi Lexi, the code for your radio should be 5493 or if that fails 1493
Assuming it is a Blau Punkt radio the serial number (starting 'BP' then 12 numbers, though the fifth 'number' may be a letter) that I need, will be on the back and/or side of the radio body, only visible when the radio is removed from the dash...
Still don't recognise that format of numbers, but removing what appears to be 'extras' the code that I get is 3952 or 1952, sorry that's the best I can do.Hello, when I take off the front of my radio the cereal number on the back is 66670023478 NISSAN MMR CD-G
I can't actually pull out the radio so I've tried taking a photo of it that I can't seem to add to the commentso what I can make out is: BP7-VA 2892-0165252-23 AV01 8241.
Hi, try 5088, or 1088 if that doesn't work...Hello to all! I had the same problem when the mechanic changed the battery. Now I have to wait an hour with the ignition on to unlock the "wait a hour" right?
I don´t know if you can still help me but, dear John_D the car is a Micra 07-2007 and the codes are:
Blaupunkt:
BP538962431371
the other is:7645389318
Thank's for your help.
5259?Got it!
Hi Rob, try 7746 or if that fails 1746Hi there,
I have the same problem, dead battery and now the "no code".
BP334947262876
7643349318
Many thanks in advance
Rob
Many thanks John, I'll give it a whirl tonight and let you know.Hi Rob, try 7746 or if that fails 1746
Hi Claudiu, the code you need appears to be 0676..please a radio code
BP234746088889 ,7642347318 Many thanks in advance
Not Blaupunkt, but Clarion I think, I can't decode themHello all!
Could you please help me with a code:
Blaupunkt CM0023 9 8820846
7612830023
Thanks in advance!
Try 5739, or if that fails 1739Hi, please any chance you can help regards my daughters 3dr Nissan Micra Oct 2003
she recently had a blown radio/audio fuse and now she needs a code as she has looked and she has lost it, we found a number at the back of the plastic housing (1653) but it has not worked, is there any chance you could help, would be a very appreciated and less hassled/pestered Dad.
number on back of radio is Blaupunkt BP334936353260
7643349318
many thanks.
