I'll try tomorrow and see, thanks!Hi, try 5581 or 1581.....
Hi, only one possible for this, 0247.........hi there if you could please help with radio code BP334947332367
if you could help I would be so grateful
K12 Radio Code Thread
This is the official thread for K12 radio codes.
Please provide your serial number (starting with BP) in reply to this thread.
Please bear in mind that the generous people that provide these codes do so in their spare time so please be patient when requesting a code.
Hi, try 5896 or 1896.....Hi! can you help me please. I have a Micra 2005 k12 and i missing a radio code.
BP536258445165
Thank you!
Well the original unit you are removing should have the code of either 7864 or 1864 and the 6 CD player replacing it should be 4171 or 0171....Sorry, can't believe my first post after introducing myself is for a codes.
I wanna try a 6 disc player with a serial number of BP536556447615
The little cd unit I'm taking out has a serial number of BP538962397229. I've found a 4 digit number in the pack on a scrap of paper so would need to see if it's the code for the one in the car already before I unplug it.
Thanks in advance for any help.
Apparantly only one possibility for this one, 1962........Hello,
I have had work done on my Micra and the battery was taken out and I don’t have the radio code.
Can you help me?
My BP number ; BP538471216058
It’s a 55 plate Nissan Micra 1.5diesel
It was the 4 digit code on the scrap of paper and the other code worked a treat.Well the original unit you are removing should have the code of either 7864 or 1864 and the 6 CD player replacing it should be 4171 or 0171....
Hi, 5896 is good, my radio is work! I am very happy! Thank you!Hi, try 5896 or 1896.....
thank you very much John very much appreciated !Hi, only one possible for this, 0247.........
I will try this thank you very much!Apparantly only one possibility for this one, 1962........
Hi, try 4104 or 0104...........Hey Folks
Having similar issue with my 2007 K12. Had work done on it recently which involved the battery out and now the radio is asking for a code.
Took the radio out to get the details;
It is a Blaupunkt S/N; BP5384 6 1724508 and Nissan MMR # 7 645 384 318.
Can anyone help please/
I'll try later mate, much obliged
Hiya John_D just managed to drill out a screw on side of daughters radio ? now have the number:- BO334936388724 I'd be much obliged for a code mate Dave JHi Dave, try 3944 or 1944.......
I hope that's a typo and the 'O' is a 'P'? Assuming it is, the code you need is '1490'.......Hiya John_D just managed to drill out a screw on side of daughters radio ? now have the number:- BO334936388724 I'd be much obliged for a code mate Dave J
It was and cheers mate ?I hope that's a typo and the 'O' is a 'P'? Assuming it is, the code you need is '1490'.......
No problems, right place for this requestHi sorry if I'm posting in the wrong place...I'm new to this forum thing ? I just bought an 05 micra and would like a radio code if anyone can help? the serial numbers that were hand written in the info I got with the car are serial number BP53655644079. TIA. photo of info attached as quite a few numbers ?
Ah thank you...possibly a 1 at the end of that original number...No problems, right place for this request. However you have left one number out of the serial number, there should be 12 numbers after 'BP' not 11............☹
Hi, try 9458 or 1458.....
Well in that case the code that you need will 'possibly' be 2740 or 0740.....BP536556440791
Hi Kevin, try 4997 or 0997......Hi,
I haven't listened to music in my car for over 3 weeks. The radio is now asking for a code, which I don't have
Serial: BP234631989291
Part number: 7642346318
Please help!!
Cheers Kevin
Read the thread...........Hi, what information do you need for a code to generate?
tia
Martyn
Ahh, yes I see now... I only had this page come up and it’s on a phone so didn’t see the nav bar...Read the thread...........![]()
If you can supply the correct information, an unlock code will be forth coming..Ahh, yes I see now... I only had this page come up and it’s on a phone so didn’t see the nav bar...
No problemsHello John_D you must be fed up to the teeth of radio code requests?!!
Here’s my story, already had a radio/cd changer WITH the code which was in my mother’s car when she brought it a month ago. The CD was jammed with 7 x discs (should be 6) and we thought - draining the battery. So, took it out and then couldn’t get it back together. My husband went on eBay and brought another one WITHOUT the code grrrr We tried changing the motherboards over. Nooooooo having none of it. So please please could you get me the code for BP 536556442350. Much appreciated
Well the code you have (2462) is the correct one for the radio....I suggest that you are inputting it wrong, or more likely not using the correct button to confirm it. Search Google you tube videos on putting in radio codes on the Micra......Hi there just wondering if anyone could help. My battery died and now I need a radio code radio model bp334936393777 I have an old code which is 2462 but it doesn’t work.
Thank you
Thanks so much, the code worked ? really appreciate your help ??Well in that case the code that you need will 'possibly' be 2740 or 0740.....![]()
Hi, try 9144 or 1144......Hi, can you help me? I need the my radio pin code.
BP234631987668
Please...
Thank you,
Laszlo Beke
Hi, try 2853 or 0853.............Can someone help with a raio code please?? My serial number is :BP538463842237
7645384318
Thank you so much for that ??Hi, try 2853 or 0853.............
Hi, try 2963 or 0963........Hello John_D! Could you help me with my silent radio? I'm looking for the radio code for Nissan Micra Hatchback k12 2005. The help will be much appreciated! BP334947337739
-Juulia
Thank you so much! 2963 workedHi, try 2963 or 0963........
Thanks very much John_D. You're a legend.Hi, try 4104 or 0104...........
Here you go, either 7935 or 1935 (or possibly both....?)Hi there! New member here, just picked up a bargain 1.6sr for £260 but seller didn't know radio codeCan anyone help me with a code for:
BP5387 6 1153037
Thanks in advance!!
