Hi try 8990 or 0990.........Hi ya would u be able help me got number off my radio BP538769676533 can u help with code for Micra
Well doneBP334958135662 believe this the code you need took me a hour to find it so hope so lol
Thank you x
Thank u so much will give it agoHi try 8990 or 0990.........
K12 Radio Code Thread
This is the official thread for K12 radio codes.
Please provide your serial number (starting with BP) in reply to this thread.
Please bear in mind that the generous people that provide these codes do so in their spare time so please be patient when requesting a code.
radio code needed for nissan k12 s/n bp334947303398 part number 7643349318 i have a radio code of 0709 which was on a receipt but this dosnt work if someone could check pls be much appricated thank youK12 Radio Code Thread
had the one hour wait 5 times goes to 0000 after an hour but wont accept coderadio code needed for nissan k12 s/n bp334947303398 part number 7643349318 i have a radio code of 0709 which was on a receipt but this dosnt work if someone could check pls be much appricated thank you
Not suprised it doesn't work, the right code is 8994 or 0994.......radio code needed for nissan k12 s/n bp334947303398 part number 7643349318 i have a radio code of 0709 which was on a receipt but this dosnt work if someone could check pls be much appricated thank you
Looks like 1889 is your lucky number.......I would be very grateful if you could provide the code for this radio:
BP 5384 6 7187404
Thank you very much.
Perfect thank youWell doneThe code you need is either 4191 or 0191 (or perhaps both will work?).........
Not the right numbers to get a code. Read the thread to find out what is required and if your radio is one that I can supply a code for......Hello please give me a security code for radio on a 2004 nissan micra k12 radio # is 55610045107 NISSAN MM CD-K(BLK)
Great, no problems, try 2779 or 0779........Hello again i have found the serial# to get the code BP3349 3 6390090 please supply a code to unlock my radio. Thank you!
Ok thanks i will let you know if it works. For the moment i have to wait 1 hourGreat, no problems, try 2779 or 0779........
2779 works! thanks a lot! you are great!Great, no problems, try 2779 or 0779........
Hiya, same story. I THINK serial number is 281856139583K12 Radio Code Thread
Hiya, could one of you kind folks help me with a radio code?K12 Radio Code Thread
Hi Dave, try 3944 or 1944.......Hiya, could one of you kind folks help me with a radio code?
Serial number is:- BP334936391692
I'd be much obliged, Dave J
I'll try later mate, much obligedHi Dave, try 3944 or 1944.......
John you're a star, worked! Cheers mate. Daughter now happy.I'll try later mate, much obliged
No problems, 0212 should do the trick.........Hiya, I've finally taken my stereo apart, just to find I didn't need to...
But if anyone could help me with a radio code I'd be really appreciative!!
BP 536556441786
Many thanks!
Sent from my CLT-L09 using Micra Sports Club mobile app
That's amazing, thank you so much! I really appreciate that you could help!No problems, 0212 should do the trick.........
Sorry , I can't decode the later sat nav units even if they have a 'BP' number. You might find a car audio specialist that can do it but I suspect that you will have to go to a Nissan 'Main Stealer' and get royally robbed for the information...Hi
Really hoping you can help as just stumbled across you! Forever in your debt if you can!!
Bought my micra with no manuals and have just had to replace battery! Obviously my sat nav / radio no longer works and I have managed to lock myself out for 60 minutes but at least that has given me the following:
Serial no: 3140742
Device no: 7612830023
Date: 10.05.17
If you can help me out that/ point me in the right direction, that would be awesome!![]()
Thanks so much for getting back to me so quickly ... at least I know to stop searching now! Appreciate you taking the time to let me knowSorry , I can't decode the later sat nav units even if they have a 'BP' number. You might find a car audio specialist that can do it but I suspect that you will have to go to a Nissan 'Main Stealer' and get royally robbed for the information...![]()
Hi, try 6020 or 0020........Morning,
trying to sort out my grandad in-laws micra, any chance you could help with the radio code please?
Series: BP634027903747
much appreciated
Thank you very much.Hi, try 6020 or 0020........
Hi, try 9458 or 1458.....Hi, I bought Nissan Micra model year 2004. (K12) Car's battery was empty and radio code isn't known.
I found these codes behind the radio: BP334936362736 and 7643349318.
Thank you if you can help me!
No problems, this is the easy bitWhat a mission that was. Didn't expect to have to remove most of the dash. If you could help, it would be much appreciated. Radio codes on back of stereo are: BP234631964548 and 7642346318
Fantastic. You are a life saver. Car is the wife's and had a flat battery. She wasn't happy after I removed it to charge and the stereo no longer worked.No problems, this is the easy bit, try 8943 or 0943, I suspect that both will work..... If you think that getting the code was a mission, wait till you have to replace a lighting fuse or even replace a headlight bulb....
Hi, try 9509 or 1509.......Hi can anyone tell me the code for radio serial number: BP334958125535
very much appriciated.
No, Fujitsu manufacture not BlauPunkt..... This looks to be an Australian market radio...?Hello,
Not sure if you can help as my serial number starts with ESP
Serial number ESPG101001
Model: Nissan Micra K12
suo: 1791839
Thank you for your time!
Hi, try 4018 or 0018......Hello good morning,
could someone help me please, I have bought a micra CC and apparently the battery was disconnected so is asking me for the radio code and I can't find it. radio serial number: BP538458558753.
Thank you very much, is really appreciated.
Thank you very much John, Is much appreciated.Hi, try 4018 or 0018......
Radio code neededHi, try 4018 or 0018......
Hi, try 5581 or 1581.....Radio code needed
Hi, I recently bought my micra but don't have my radio code. Serial number BP334958149563 if anyone could help I'd be grateful , thanks!
