Hi, I had to change battery & now radio needs a code, it's BP536258039683, can anyone find the code?
Hi, try 1657.......Hi, I had to change battery & now radio needs a code, it's BP536258439919, can anyone find the code? The silence is soooo boring. Cheers
Hi, try 8575 or 0575......Hi, I had to change battery & now radio needs a code, it's BP536258039683, can anyone find the code?
Hi John, 8575 worked... many thanksHi, try 8575 or 0575......
Thanks John, worked perfectly, u r a starHi, try 1657.......
Hi, my Christmas gift to you is the number 0403.......Hello there!
Micra K12 Radio code need please!
Radio model - Nissan MMR CD-G BP538469481872
7645384318
e1 - 024173.
Thank you. Merry Christmas and a happy new year!
Hi, try 8353 or 0353......Hi guys!
Happy holidays to everyone
I recently had to fix the starter on my car amd of course the radio now wants the code.
I really would appreciate your help
The SN is BP538469468780
The part no is 7645384318
Hi, try 9314 or 1314......Hi, I'm locked out of my 2009 Micra's radio - would it be possible to get a code for:
S/N: BP738398787393
Part no: 7647383318
Thanks for your help!
hi,my code is BP334958136307K12 Radio Code Thread
This is the official thread for K12 radio codes.
Please provide your serial number (starting with BP) in reply to this thread.
Please bear in mind that the generous people that provide these codes do so in their spare time so please be patient when requesting a code.
Hi, try 5303 or 1303.....hi,my code is BP334958136307
7 643 349 318
O22458
Thanks in advance if you can h3lp
I suspect that you have written the serial number down wrong. If there is a letter in it it is always the fifth digit, not the sixth.....Hiya guys,
I hope everybody had a lovely Christmas! I'm in need of a k12 Micra radio code for:
S/N: BP73839B782175
7647383318
e1 - 034173
Thanks in advance!
No problems, try 6702 or 0702......Thank you for that! You are right the serial number is in fact BP738398782175.
Thank you so much for that, it's really kind of you to do this!No problems, try 6702 or 0702......
Bp334947304627
Nissan mm cdk
7643349318
Looks like the same unit (6CD) as in my Sport+. the number that you need to find is engraved on the side of the lower part of the unit, as shown in the (not very clear) attached picture.I'm guessing this is where the serial number was... View attachment 66814
Sent from my CLT-L09 using Micra Sports Club mobile app
Ok thanks loads John, I'll have a look now.Looks like the same unit (6CD) as in my Sport+. the number that you need to find is engraved on the side of the lower part of the unit, as shown in the (not very clear) attached picture.
It will start with'BP', followed by twelve numbers....
Hi, try 8088 or 0088......Hello, can someone help me? i need my code for my radio...
bp7383 8 7794634
thankyou.
Hi, try 5715 or 1715....Hi. Looking for a radio code please x
BP538971320726
Thank you ?
You have left out a number in the 'BP' serial number, there should be 12 numbers after 'BP' not 11......Hi John
Please can you work your super magic and source a code for
BP 53847122040
7645384318024173
OoopsYou have left out a number in the 'BP' serial number, there should be 12 numbers after 'BP' not 11......
Hi, try 9680 or 1680...........Ooops
Please add another zero to the end!
Thank you !! 8088 was the right code! XHi, try 8088 or 0088......
Hi, 1211 should solve your problems.......Hya I changed my battery and now I don’t know my code on my Nissan micra 2003
bp 234732026331
Hi, try 4100 or 0100.......Hi lads
could someone help me with the radio code for Nissan Micra 2005 SX? I lost mine unfortunately.
BP334958116044
8 635 123 392.0
Many thanks!
Check the 'BP' number again. There should be 12 numbers after 'BP', not 11.......Please can you help find the code for my micra? Serial is BP234635 196 75 and the other numbers on it are ODK 7642348318
Just took a photo of the numbers so I can't go wrong! It's BP234632519675Check the 'BP' number again. There should be 12 numbers after 'BP', not 11.......
The missing '2', in the middle, makes all the differenceJust took a photo of the numbers so I can't go wrong! It's BP234632519675
First one worked a treat thank youThe missing '2', in the middle, makes all the difference. Try 8939 or 0939.......
