Thanks a lot I'll give it a go tomorrow!Here you go, either 7935 or 1935 (or possibly both....?)
Hi, try 6555 or 0555......Hi,
Anyone can help me, please?
serial number :BP234732058159
part number :7 642 347 318
Thanks in advance
Hi, try 9440 or 1440.......Hi,
Can anyone help me, please?
I just received my car back from the garage and I need a radio code.
Serial number is: BP334947308754
Part number is: 7 643 349 318
Thank you in advance![]()
Many thanks John.Hi, try 9440 or 1440.......
Top man, worked a treatThanks a lot I'll give it a go tomorrow!
hi JohnHi, try 6555 or 0555......
The codes are correct for the serial number that you gave me, either you are inputting it wrong or more likely not pressing the correct button to accept the code after putting it in. Try Googling for videos on Micra radio code procedure......hi John
sorry but the codes didn't work
And I assume nothing happened? Try it again and this time try all of the other buttons (other than the number ones), one at a time. When you hit the right one everything will work. Not all of the radios use the up arrow some use the T/A key and there may be other accept buttons.After entering the code, I pressed the up arrow button, all the videos explain like that
Well I'venever decoded one with the serial number starting with '8' (I know that the sat.nav units starting with '000' can't be decoded with my software......Anyway, the computer says 1726, give it a try......Hi.
I need a code for Blaupunkt memphis SQR 88
GM8884A3222448
BP8884A3222448
7 648 884 420
Hi, 1694 should be the answer......[QUOTE = "scheichuwe, post: 396931, membro: 9298"]
Discussione codice radio K12
Questa è la discussione ufficiale per i codici radio K12.
Fornisci il tuo numero di serie (a partire da BP ) in risposta a questa discussione.
Tieni presente che le persone generose che forniscono questi codici lo fanno nel loro tempo libero, quindi ti preghiamo di pazientare quando richiedi un codice.
[/CITAZIONE]
BP536358035971
No problems, 0154 would appear to be the answer to your prayers...........Hi there,
Can you help me with the code for a
BP 5365 5644 6824
LP 8 653 123 520
I was checking why I had the airbag light on and I've disconected the batery, then I noticed that the code for the radio was nowhere to be found.
Hi, try 8421 or 0421......hey John-D pleas can you help me with my radio code from the micra K12
BP538469487185
Hi, try 6309 or 0309.......Can you please help me with the code for Radio Serial Code BP334947320799
Hi, no problems try 7638 or 1638.....Hi All, could anyone help get the radio in my Granddads car working? The serial code is BP334936348609.
Many thanks in advance.
7638 got it, many thanks!Hi, no problems try 7638 or 1638.....
K12 Radio Code Thread
This is the official thread for K12 radio codes.
Please provide your serial number (starting with BP) in reply to this thread.
Please bear in mind that the generous people that provide these codes do so in their spare time so please be patient when requesting a code.
Hi could you please advise my radio code for my Nissan/clarion radio PP-3151R-A aerial nimber CL0945 C 0063154 thanks Pete6792
Hi, not enough numbers after 'BP' there should be 12, you are only showing 11.......are you missing one between the 8 & 6 at the beginning?Hi.... I'm after stereo code for Nissan cd player bp8 635 123 393 0..... other numbers 28 185 AX613. HP-3123. Hope you can help.....
Check the 'BP' serial number, you have posted 11 numbers there should be 12.........Hi please could someone find a radio code for my sons MIcra he disconnected battery and doesnt have it. Radio serial no is BP33493637242 part no is 7643349318 many thanks in advance.
That's bettersorry its BP334936372442
Hi, try 6105 or 0105.......Hello,
I'm new hear and need the radiocode for an Nissan Micra K12 (2004)
BP334947301469
Hope you can help me
Thank you.
Hello,Hi, try 6105 or 0105.......
Hi, try 9735 or 1735.....Good morning guy, i need help for my 2003 micrak12... i lost the dtereo code and i need them!
the serial number it's: BP234732037873.
thanks in advance and free drink for the answer
Hi Folks...Please can you help get my music back? Desperate for my code...BP538471215924 Thanks! Rachel.K12 Radio Code Thread
