paddle clutch
Mate what make of clutch is that? if you dont mind me asking where did you get it from and how much?
Car is coming along well
Cheers
Peter
also are my alloys the super s ones as im have trouble locating the caps
bike carbs due to be fited on sat had too go back a inch too long will get pics up tues need some socks for them now if any one has?
were bouts in sheff you live haven't seen you driving around yet
awsome almost as loud as the exhaust lol
needs a low pressure pump and take the origianl out
bit of an update an spec list
specs-
engine
-ap forged pistons and con rods
-lightened and balanced crankshaft and flywheel
-helix racing paddle clutch
-ported and polishes head with 3 angled valves
-piper ultimate camshafts (to be fitted)
-high performance 8mm plug leads
-ashley exhaust system inc manifold
-custom inlet on bike carbs and performance air filter
Hell of a spec on the engine mate, I thought AP only did clutches and brakes, didnt know they did forged pistons and con rods was that a special order?
For the carb set up you want to be running no more than 1.5 bar or it will be over fueling, you would be better off getting a facet fuel pump and a regulator.
What ECU are you using?
