I feel stupid for not considering this before, I had a nagging feeling that I should really sort it out but just hadn't got round to it. No symtoms had shown their head. I will be fixing it post haste.
Yesterday afternoon while driving down the local bypass at 60-70mph a car changed lanes unexpectedly. I stood on the brakes, as might be expected in such a situation. In hindsight a bit of an overreaction as the speed differential between our two cars was not actually that great.
Unfortunately I braked to such an extent that the rear wheels locked, which sent the car into a side ways slide, I wound on some opposite lock and came off the brakes, by which time the car was at about 45 degrees to the carrageway, it then bit and sent me back the other way. I managed to gather the fish tailing together, but I did need most of both lanes, fortunately no one was on the nearside, the van I was overtaking was still a little way behind.
So all ended well, it was just a "moment".
On to considering why it happend, well firstly I could have been paying closer attention, and reacted in a more measured fashion. I could also have been wearing different shoes - the fairly new, un broken in Birkenstocks provided little in the way of feel through the brakes. I might have cosen to fit better grippier tyres, and use a tyre pressure that favours ultimate grip over fuel economy. It could cetainly also be attributed to the stiff springs bounce not being controlled by the low damping ability of the standard shocks. However I think the biggest cause for my situation was the rear brake load compensator.
K11's have a brake bias compensator built into the rear brake circuit that allows more braking force to be applied if the car is carrying a load. How does it know the car has a load? - it rides lower. The brake compensator is essentially a valve mounted on the car body with an actuating rod mounted on the suspesion, as the susspension compresses under load it opens the valve to allow greater fluid flow and braking pressure to the rear. Beacause my car has been lowered it "thinks" that it is carrying a heavy load, and allows maximum breaking force to the rear, even when there is nothing in the back to increase the force on the rear wheels, and friction between them and the road surface and stop them from locking.
So my next step forward is to investigate the possible adjustment on the actuating rod, or prehaps modification of it to take account of the lowered susspension. I'm off the road for a bit now anyway as the MOT expires today and I have no time to carry out the required work until next week (CV boot + whatever else I or indeed they find).
I know solarice mentioned a modifiaction to it in his blog, so I'll have a hunt through at some point. If anyone else has already done this, what did you do?
And if yer driving a low micra that hasn't had this issue addressed, then it might be worthwhile having a look.
Mark.
Mark.
