DEI lol. I'm suprised ollyc98 didn't come up with that one
Do you think John Garrett invented the perfect turbocharger with his very first attempt? At least I HAVE THE SACK to THINK OUTSIDE OF THE BOX
You should take a short walk on a LONG PIER,
If he wanted more boost and a charger is 80% why not just run 2 chargers?
I have heard of the ceramic engine before, but to my knowledge it was prohibitively expensive, and also prone to shattering if the slightest thing went wrong.
Edit: Quote Wikipedia:
In the early 1980s, Toyota researched production of an adiabatic ceramic engine which can run at a temperature of over 6000 °F (3300 °C). Ceramic engines do not require a cooling system and hence allow a major weight reduction and therefore greater fuel efficiency. Fuel efficiency of the engine is also higher at high temperature, as shown by Carnot's theorem. In a conventional metallic engine, much of the energy released from the fuel must be dissipated as waste heat in order to prevent a meltdown of the metallic parts. Despite all of these desirable properties, such engines are not in production because the manufacturing of ceramic parts in the requisite precision and durability is difficult. Imperfection in the ceramic leads to cracks, which can lead to potentially dangerous equipment failure. Such engines are possible in laboratory settings, but mass-production is unfeasible with current technology.
In modern low emissions cars the exhaust gas may be fed round again inorder to burn off unburnt fuel, this cannot be done indefinitely and without new air or getting rid of the spent exhaust it will simply die out.
i think every ones missing the point entirely engines are just basically air pumps the main problem with his idea is not the heat the lack of oxygen ect. it is simply that you cannot keep adding and not have any exhaust the only things known to man that do this are black holes.
a zero emisions combustion engine is not possible in the nothing coming out sense of things.
a zero emision engine would still have an exhaust its just that the things coming out arent poisonous.
hydrogen engines burn very cleanly, as do alchohol powered engines, water engines have been made but unfortunately the process needed to split the water into hydrogen and oxygen suitable for combustion uses more power than the engine makes from burning the fuel.
plus if you burn pure oxgen and pure hydrogen your exhaust would mostly be water!
Ed, what he's saying is that if you fed the exhaust back to the intake, no gasses would ever escape, but as you keep adding petrol etc there is more and more going into the engine and nothing escaping.
A black hole also has loads going into it and nothing can escape once it crosses the event horizon. That said blackholes do emit a lot of radiation. So some stuff gets out. The point is an engine isn't a blackhole, therefore if you kept putting in something would have to give.
