Yesterday I got all the front lights wired up and made sure everything connected is working.
Washer bottle all works ect apart from being empty. Driverside sidelight and bumper indicator don't work because the guy who welded the new frontend on cut the wiring and scrapped it with the old front panel grr so I need to make a new section of loom or retreive the peice I need from a breaker.
The headlights just flicker and make the relay click, I have removed the relay and cleaned it. I have also disconnected all the plugs and gave them a clean, it all appears fine, yet the headlights just don't work on dip. Hopefully they will come back to life.
I started making the exhuast manifold as I have written above.
Collected lots of exhaust systems for making the new system.
Sent money for twin 36 dcnf conversion.
I also started to strip all the rubbish off of the cg13, that I won't be needing. The inlet was a pig to remove but came off fairly easy in the end. Got rid of all the loom brackers and clips.
Washed it all down with thinners.
Fitted nismo oil cap.
I still need to take the gearbox back off so that it can be cleaned and painted. Also need to shave the heads off of the flywheel bolts as they are to long.
Is there any tell tale signs that I can use to make sure I have the correct gearbox? I didn't have to drill out any holes and it bolted straight on. The front gearbox mount only lines up on 2 of the 3 holes also. Apart from that it all looks good imo
