Where can I get the 1/2 link from.... thanksGot a bag of these![]()
Cheers....Think i got mine from rs components
Loads of sound proofing tar in the footwells you can remove, which save even more weight.
Dry IceTips on removing it?
Wait for a very cold day and hit it with a hammer.Tips on removing it?
Tip petrol on the floor it literally dissolves itTips on removing it?
Do you have output on the ecu?New steering wheel....
Removed the trumpet servo and controller stuff, may have to make something more ‘digital’ to get it to work how i want it
Where you purchase the trumps or velocity stack?
Enviado do meu ONE E1003 através do Tapatalk
Can you share a link, must of them I see don't have this design, or I'm search on wrong sectioneBay
Oh they sound like Frank ideas if I ever heard them. Definitely seen something about it when I was reading a post about tuning. Called cg engine tuning or something.Just bought another head to try some diy porting/polishing.
Have asked a couple questions on the Facebook page, but il ask them here too so I’ve got a record
Read something about using cr12 solid buckets, what’s involved with fitting them......I guess it’s to stop from the shims being spat out?
Any suggestions on what springs to use, Catcams have been suggested to me......I have no idea what ones I need![]()
Also read a few things about qg18 valves being used
Send the head to Portugal, in veicomer will machine the head with cnc port, with all you want
Yes a little but, it's a good work lolSounds expensive![]()
Beings the head only cost £20, it won’t matter if I mess it up trying to polish/port it
Do you just fit the standard CG10/13 over bucket shims under the CR buckets and are they the same part as CGA buckets?
the later cg coilpack have shimless buckets ^ and valvestems that are 2mm longer, i assume the cr ones are the same.
as for valves, i think the inlet and exhaust valves are made from the same material neil, so that could give you some options
you need to cut the seats neil, quite deep to account for the shorter stem, combustion chamber cc wont change much
