The other day i got the first few mods on the front of my corsa b coilovers.
today i got the most pics i could to explain in simple terms how to do it, this is what i done first.
first i tied up the micra spring to take the tension of the spring why i buzzed the top nut off.
then i took pics of the micra componants you will need to keep.
the micra top suspension mount, the bit that sticks up try to follow the same mesurements.
the steering washer that makes the suspension leg turn, you will need this.
how it sits on the micra suspension top mount.
both micra and corsa top mounts, micra - left.
corsa b top mount lathed to the same demensions as the micra one.
