CMF_nz_aj
» CMF MemberI've now seen a second car where you have to hold the button to close the glovebox, otherwise if you just push on the door, the catch pushes the barrel out.
My facelift K11 has a different style glovebox with a big handle. Wondering if it might retrofit into a pre facelift K11. The dash is quite different, the top vents, & the warning & jeated rear screen buttons have all moved up a livel & there's a double height radio hole.
