Much better!does the lock, lock when you turn the key from the outside? because if the central locking works when you push the lock by hand but doesn't when you move the lock with the key then it must be somthing conecting the the lock barrel with the puch lock...... if that makes sense![]()
yes mate, any coilpack (post 2000) are shorter
and a longer cat..........and a shorter downpipeSo the difference is just in the mani then pal?
i was,nt wrong then alexIt knocks on the front ARB :/
yes the cat was made about 4" longer because its a 1 cat system, so they made the mani and downpipe shorter to suit
you will probably find it breathes better too, the coilpack cats i,ve seen were very fine pored![]()
you stole franks pic !he got it much higher
aye, blue with black stripeWill be a signal wire from ecu I'd imagine, not seen coilpack ecu loom diagrams going round though...
aye, blue with black stripehttp://www.micra.org.uk/threads/tachometer-installation-for-facelift.55763/#post-583328
Thought you didn't need one Alex![]()
Noise test?Only need it for scrutineering....
Noise test?
Sounds like itYeah...
Been getting like 86db with a standard exhaust so am probably revving it too much![]()
PLR only goes to 98Db iirc, Well its supposed to anyway![]()
You don't have a janspeed though, but them I remember you don't have PLR either do you?
Loctite sealantDoes anyone have preferences for the exhaust manifold gasket? As in, what make to go for?
Loctite sealant![]()
genuine Nissan gaskets obviously![]()
I use these. Never let me down. That's for a pair as well.
http://pages.ebay.com/link/?nav=item.view&id=261179632646
Ready for the season now mate
All in good time Steve![]()
Aye plus your other mods you've been atStickers have added a lot of power eh
nah, different alexAnyone know if the cam cover gaskets are the same on coil pack and dizzy type engines?
nah, different alexand plastic japspec ones are different again
