Twyford Wood Stages Rally 2016
Before I go any further, this rally was on a day of nigh on 30 degree weather, aka I was hot as fook throughout the day and not always thinking properly!
I never have a service crew, it's just me and my co-driver who both know a little about cars so as soon as the stage is over we jump out and try to fix it - Meaning in hot weather its a hard hard day!
First stage I was worried about the brakes but they turned out to be brilliant, however we were having issues with the car randomly cutting out for a few seconds and turning back on again. After the first few stages, even with our issues we were first in class which was surprising.
To fix the stuttering I started by looking at the fuel pump, popped the cover off and one plug was loose so I cleaned all the dirt out and it clicked positively in place - problem solved I thought, but no!
Another stage later and the brakes felt soft so I whipped the wheel off and found that one brake calliper nut (the ones you take out to change the pads) had fallen out and the other loose so the calliper was moving instead of squeezing the pad, a frantic look later and luckily I had a spare bolt - brakes felt fine again.
Stage 4 - the car cut out mid stage and I had no tools with me, I simply pulled over and waited till the end of the stage to get towed back in
Luckily it was lunch now so I had an hour and a half to fix whatever was wrong.
There was no voltage getting to the pump itself so i suspected the relay was gone and sure enough it was so i bridged it and the car was fine (however this took me ages to find out and by this time it was after stage 6!!!!)
Got back in the car and my god it was flying, car felt massively fast and the stage times were brilliant - we should have, and would have, lead the class by miles but I didn't
So we ended up 4th in a class of 10, and 24th out of 74 starters - not bad at all!
If i hadn't broken down and got a stage maximum (cost me 7 minutes) I would have lead the class by 3.5 minutes but oh well, I was just happy to finish.
