There's a parcel shelf with speakers out the yard I go to, it's a bit tatty so I haven't bothered to have it.I want rear speakers too!
Blimey Andy - I would never have got that out with a hacksawToday I removed some more parts from the green Micra including the indicators, interior light oh nearly forgot part of the rear roof lol! :-S View attachment 51492View attachment 51493View attachment 51494View attachment 51495
Blimey Andy - I would never have got that out with a hacksaw![]()
I think so. Twas DarkA black parcel shelf? B-)
I would put them on Andy, just as well to have her chromed all over - she nearly is now (!)The shiny chromey door handles arrived from Holland today I think Steffi Cab will like them also still thinking about adding the shiny chromey mirror covers but not sure? :-S
Andy B-) View attachment 51598
Have relays on the way. And sidemounts for the seats...
Bolting them throughbthe floor. Cos frig it.
Sent from my SM-G920F using Tapatalk
Hello Andy. Good stuff there buddy.Bought this JDM AK11 cupholder and surround might swap it for the double cupholder in the Cab or fit it into the SR? B-) View attachment 51601View attachment 51602
Pity you can'tget them in chrome LOL
Sorry could not talk this morning (meeting for work)
1 of 657 1.3 slx's left in the UK passed the mot today![]()
I'm going to tell you how I have done the seized/rusted screws in the past and you can decide if you try it,, I use a slow drill with a new sharp drill bit slightly smaller than the screw head and carefully slowly drill until the head falls off. Then you can get the cover off to expose about 10mm of screw which you should be able to remove with a pair of stilsons.. a good clean around the the screw with some penetrating oil overnight or hold a soldering iron to it as the heat can break the seal if you are luckyI started a rust repair/renovation of my engine bay yesterday. Removed and painted the exhaust manifold, battery case, metal brackets for throttle cable, lambda sensor. Painted the intake and the air box. Run into the issue of stripping Phillips screws on the cam cover, so added a few drops of acetone and PSF mix and left it overnight.
Today added an extra coat to my manifold, and found out that painting plastics with Halfords paint without a primer was a mistake. Now ordered some plastic primer and matte paint. Returned to the cam cover and literally spent 3 hours trying to undo 4 bolts, in the end got 2 out with the help of a file and vise grips, but one of the screws that is stripped and rust welded is the one next to the distributor, towards the back of the engine. No idea how to get it out, it is a tight spot so my vise grips will not fit even with the distributor removed.
I think the best shot at tackling that bolt would be to remove the distributor, how do I do that? Do I need to remove the distributor cover, because it has Philips screws too, which will not budge, and I do not want to strip more. I do have a set of hex bolts to replace the cam bolts and two longer ones for the 10mm distributor bolts so I do not mind damaging the heads of the OE.
"The file size is too large for the server to process"
when I try to upload pictures, any idea how to fix this?
Love the wheels!Also started to repair the side sills and had a quick looked at the rear disc brakes!View attachment 51623View attachment 51624
I'm going to tell you how I have done the seized/rusted screws in the past and you can decide if you try it,, I use a slow drill with a new sharp drill bit slightly smaller than the screw head and carefully slowly drill until the head falls off. Then you can get the cover off to expose about 10mm of screw which you should be able to remove with a pair of stilsons.. a good clean around the the screw with some penetrating oil overnight or hold a soldering iron to it as the heat can break the seal if you are lucky![]()
Is there a code for the radio? I saw one in excellent working order in a pre face lift new to my local scrapy and am tempted![]()
From EBAY. Sold as not working but works great. Cassette Tapes don't play but I have one of those adapter on a wire things and that works good so I'm happy. I think it's out of a pre Face so doesn't sit flush but I don't care.
Sent from my SM-G850F using Tapatalk
This particular one didn't have a code. It was just a plug and play job luckily. The only downside is since my Car had an after market CD Player fitted, The mounting brackets weren't present so I had to make do with the cage thing that's there instead.Is there a code for the radio? I saw one in excellent working order in a pre face lift new to my local scrapy and am tempted
The cover on my '94 1.3 and the wee boston and the 1.0lx were all smooth in the cover. This way you won't have to disturb the distributorSo what you are saying is that there are no threads in the cover? Just the head?
Thanks for a reply by the way.
Glad you mentioned the bracketsThis particular one didn't have a code. It was just a plug and play job luckily. The only downside is since my Car had an after market CD Player fitted, The mounting brackets weren't present so I had to make do with the cage thing that's there instead.
I tried the brackets I have from another micra radio but they wouldn't fitGlad you mentioned the bracketsI can grab everything in one go
Love the wheels!
And I will be repainting the intake, this time with primer.Finally finished with painting the exhaust Cam cover battery case and various other rusted bits.
Now wasting petrol waiting for the paint to cure.
Sent from my Blade S6 using Micra Sports Club mobile app
