Can't wait to see this
This car certainly owes you something mate.![]()
Floor rust complete, it was easy job took me 1 hour max, I cut the rot out in a square shape, grinded it flush so I can weld it easy, made a cardboard template cut sheet of 1.2mm mildsteel, shaped it with a hammer all fitted nice then tacked welded it on while I was shaping all the edges then seam welded it, the bottom of the floor has come out ok as well now gona grind it off and paint it the. Oil wax under car big thanks to @frank cut and weld
Suprise coming soon to end sr20deThis car certainly owes you something mate.
Is that ga16 what is passager side like on spaceView attachment 44920
Well... It's getting there slowly no chassis cutting needed!
What engine u got in ? And what gearbox space like on the chassis ?Huh?
I'm using ga16de a 2000 primera engine. And the pre face k11 1.0 gearbox.What engine u got in ? And what gearbox space like on the chassis ?
I suppose the stock driveshafts work too because of the 1.0 gearbox yeah?I'm using ga16de a 2000 primera engine. And the pre face k11 1.0 gearbox.
Gearbox clearance is fine and if you blank the water pump off and use the 1.0 crank pulley so is the drivers side.
I'm going to solid mount the drivers side engine mount as the inlet mani is painfully close to the brake servo!!!
Overall not as bad as people make out.
You have a great set up of the engine and box there as they fit nicey, what about wiring how was that, this swap isn't hard am guessing ? Are u using bush mountsI'm using ga16de a 2000 primera engine. And the pre face k11 1.0 gearbox.
Thank you it's turning out very easy tbh.You have a great set up of the engine and box there as they fit nicey, what about wiring how was that, this swap isn't hard am guessing ? Are u using bush mounts
Yes mate drive shaft fit perfectI suppose the stock driveshafts work too because of the 1.0 gearbox yeah?
Sounds simple u shouldn't have any problems with bush mounts of the ford transit van, my car doesn't viabrate on idle or reving, are u local from SheffieldThank you it's turning out very easy tbh.
I will be using the micra wiring loom with the micra's throttle body so I will only have to extend one coolant temp sensor and that will be it with the harness.
The drivers side engine mount is the only one I've had to change. I will be bolting and welding a large box section through the chassis rail then bolt the engine to that.
Obviously a strip of rubber between engine mount and block.
So the solid mount will ensure the engine or gearbox won't move.
Only downside is vibrations but i don't mind.
Would shaft be ok for power from 1.6 to 1.0 boxYes mate drive shaft fit perfect
Mines been masked for like a week... Considering my number plate is "K11 OCD" it wasn't great!!I remember when mine was masked up haha so ordered a bung special delivery to bung it asap lol![]()
I hadn't thought of transit bushes.Sounds simple u shouldn't have any problems with bush mounts of the ford transit van, my car doesn't viabrate on idle or reving, are u local from Sheffield
Should be more than man enough for the job thensame shafts that i ran in my 1.3+t setups mike, the offside one was a k10 shaft in fact
Yeh time will tellI hadn't thought of transit bushes.
I'm based in Norwich mate.
Shafts should be fine only one way to find out !!! Haha
Does ur old steering have 2 metal clips with wires on ? Looks a bit like the horn wires metal tabsSo I've fitted my omp wheel but it doesn't cancel my indicators and the steering seems really heavy now any one help ??
Can u make me a full exsault 2.5 inch all the way with my own back boxalot of money for 7 bhp! do like ive done make your own or get someone to make you one less than £100 still same gains by removing the restrictions (if your local to wigan i can make you one)
have you got a manifold ??Can u make me a full exsault 2.5 inch all the way with my own back box
was ya in love with that gear knob when ya first got itFinally fitted my new steering wheel and I'm in love with it)
Yeh that's all there need need it from downpipe to back box, Can u supply all bits and fit plzhave you got a manifold ??
Cg13 all day love thembought a cg13 engine so we'll see how that goes
