Drove 120miles to pick up a little present for Charliedoing another 400 for a little something else :laugh:
here,s an old dyno graph of mine that shows the 2 runs in closed loop (above the arrow, where the ecu is using the lambda signals to adjust the mixture to near 14.7:1), and 1 run in coldstart mode/open loop (arrowed, where the ecu is running from a stored map of around 13:1 a/f/r,s)
http://tinypic.com/view.php?pic=3k35&s=5
there is,nt much difference in power output, but you definately dont want to run lean under boost
the downside is that you end up running acceleration enrichment all the way up a long hill in 4th or 5th gear(your cat wont thank you for that fwn)
Started considering some tweaks to the engine, members posts on here are responsible for that haha. Btw does anyone know the diam of the micra crank pulley?...can't get access to measure the one on the car at the mo.
which dia kris ?
Looking for the overall diam of the alternator belt section on the pulley (larger of the two belt sections)...currrently got about 8 psi on the stock size, just curious how much bigger it would need to be to add a couple of psi
Seeing as i should upgrade the maf, its got me thinking haha.
Baby snail![]()
unfortunately I've killed my back carrying it from the car :down:
Thats good to know I need a down pipe for it
:grinning: Did some one say flange? :grinning:More than likely but it's the flange I need, been looking for one online and can't find one anywhere
Suppose you get what you paid for, going to have to rethink the tubby
1 busted blade karl ?![]()
Not worth the hassle anyway get a t2 from a fiesta plenty about and fairly cheap
What's the lowest and max a t2 can produce?
karl the turbo i sold you is t2 from s12 with t25/t28 flange.
I think its set to 7 psi standard,
what about a blower from a golf or audi? or even a renault or pug diesel? ive got a kkk ko3 that im going to be using eventually there quite popular.
yeah as frank found out recently![]()
People normally replace them for t28 iirc from the s14 that's why prices are high as the s13 boys want them as well! I was looking at a turbo from a diesel but I wasn't sure on the waste gate as they operate differently to a petrol dont they?
eye they can be welded up tho and use an external one or just mod a petrol one to fit. was just thinking if karl is wanting low boost then a kkk ko3 would be perfect but like you say also faffing around with waste gates can be a pain.
Frank have you got a pic of your mani? I'm interested how low the turbo sits
So it basically sits where the first cat is
karl you recieve my ppm?
