Photo Shoot
Y u no say hello(Lincolnshire)
First one in the car, looks ok but too many mistakes. Sussed out a new way to do my next one which will be much improved.
I'll let you know in a couple of weeks LOLI
I'd get a headache after looking at that a couple of times, I think.![]()
Well, that won't affect me thenlooks nice davyboy, but i reckon the Union Jack would be better!!!
BUT does look a brain killer!
J
Well, that won't affect me then![]()
And some actual footage of one of the tests.
That's the rising offset sun I was looking for, but that's too small.
Cheers bud - brilliantIf you email pro cut vinyl i think they should be able to make one up for you![]()
I have a few patches to do myself am dreading it. Give me a spanner any day but body work I have no clue! HahaSo decided to tackle some body work today. It's taken me 3 hours to sand down and fill a spot of rust that's just slightly bigger than a £2 coin. I'm so glad I chose the mechanical side of the trade!!
One for the kids YO !!! now, which pattern ?? Also the cut outs are smack bang on the money.
Where did you get that?One for the kids YO !!! now, which pattern ?? Also the cut outs are smack bang on the money.
Can cut out the meters, no problem now I have a pro circle cutter. Just depends how much of the sticker bomb face you want showing.....more...... or less, its a personal choice. Can't mess about to much as you only get one from each sheet.Much better, now just need to stick the meters over the top![]()
The needles go back on no problem and seem to work fine, I can cut out the face so the needles can stay on and the face fits over them. But, when doing it this way the cut outs are much larger...obviously. It also depends on what material you use whether you can do it that way or not, it needs to be flexible to do it this way. Make sure you put them back on in the same position that you took them off.@davyboy
Hey buddy. when you put the needles back on did you put em on? don't wanna put em on and have indicated 100 at idle![]()
Amazon, type in sticker bomb - they were on page one. Happy hunting.Where did you get that?
Ok thanks manAmazon, type in sticker bomb - they were on page one. Happy hunting.![]()
Id get these checked by MOT mechanic just incase mateMy favourite sticker bomb sheet, might be a bit to busy for a speedo face though.
No need M, just take them off for the MOT. They're not stuck down, remove them in 5minutes tops.Id get these checked by MOT mechanic just incase mate![]()
No need M, they light up as normal with no problems, as long as the cut-outs are in exactly,( and I mean exactly) the right position.I was gonna get a sticker done, only problem is micras dials light up from back, gonna tear my old dials apart see if theres a better way of doing it![]()
My first speedo showed the numbers only cut out, and they lit up OK. I've moved on from the first one quite a bit. Have now got the correct cuuting gear and templates to make a pretty good job of it...if I say so myself.Do the speedo numbers and revcounter light up ok though?.
I see how you've done it but I don't want to have the big green/black line where you've cut the backround out of the dials coming through, I want them as if they came factory white background red numbers/counters
