Nothing wrong with that. I have mine post-it note bookmarked already :/Sadly yes, got a copy on the coffee table!
Been good though to look through the blur book, will help for my first rallies committee meeting at the end of the month.
Ah. Grp N will have restrictions as per the Grp N regs.
That will be where the discrepancies are thenGrp N/A regs dont apply to UK stage rallies unless specified in the SR's which is most events unless at Nat A level. Most clubby events they dont apply.
I did Anglesey a month or two ago without setting the lamp pod up(no tax/insurance so couldn't drive somewhere dark) and the new HID's in the headlights stopped working the night before. Quick run to Halfords to buy some terrible bulbs and I ended up doing the night stages with headlights and a lamp pod shining to the stars. Surprised there were no planes coming to land on me from RAF Valley
Tis why I'm skintgod rallying in the forests sure does trash the underside and suspension on the car. Not sure i could cope with all the prep work doing forest events all the time!
the nut on the top of the strut chris ?went for a drive to get some pictures today, heard knocking from the front and the front passenger side top bolt keeps coming loose, any reasons why it keeps coming loose? getting dad to have a look while im at college tomorrow and he said the thread might be going bald or something.
Have you tightened it with a 21mm spanner and the appropriate allen key? (8mm iirc). A dab of loctite wouldn't hurt. Never cam loose on me mind, must be you driving like a hooliganyeah. keep tightening it but keeps coming loose.
the shaft must be turning with the steering then mate (and not the thrust bearing)yeah. keep tightening it but keeps coming loose.
Have had this on the rally car (much higher loading than road use) i use either a nylock nut and/or a anti shake/ split washer to stop it coming undo.
On WRGB quite a few other bits shook loose too including the long front wishbone bolt! All these are now split washered up.
Got my amp back from my engineer friend today, hes done an excellent job. Said he had trouble soldering the earth to the board as the earth runs through the entire heat sink case which kept drawing all the heat out of the solder lol. Just gotta drill the slot in the box and finish wiring up on Tuesday now.
Opinions accepted, however im happy with it. Hes done it (whilst aflicted by a sty in his eye) for nothing but a pint in his own free time as a favour. means i dont have to wait a month to get to my parents to use my tools. I couldnt have done a better job so I appreciate his work. Saved me alot of hastle
This mod adds between 0 and 340bhp, instantly.....................boom!
4-2-1 turned up! Getting the two first parts in place was a massive potch, and getting the bottom nuts on is a t*t!
WDIDT ?
took the CGA3 out
Are you crazy?
aye paul1.0 turbo going in Frank?
I decided I would look into cut springs today and use the fancy machinery in the shop to give me to give me data and facts about what really happens with a cut spring
I'll keep you posted
I'm going to be trialling B2 passat springs with the adjustable spring perch from a corsa b coilover kit in the next couple of monthsInterested in this Andy, was toying with the idea of cut springs from another car on the rear of mine for the time being before spending on anything else. Ford focus maybe
nah, the sun is out now scott ya wussAre you crazy?
It's wet outside. Go get a coffee.
I'll get a proper set of numbers and the effects on the spring etc etc.Interested in this Andy, was toying with the idea of cut springs from another car on the rear of mine for the time being before spending on anything else. Ford focus maybe
So far its not looking too bad.. but I thought well rather I think its this and that I'd just solve it once and for all
no mate, maybe next summer and it sounds more scoob than before ! maybe that size of unequal pipe is the sweetspot for 1000cc ehNo intercooler frank?
will do and its a fusion nistune, running ed,s basemap stillAwesome mate, have to get a video up. Would love to hear it what managment you using?
You'll never beat a true boxer engine for that noiseand it sounds more scoob than before
Here it isYou'll never beat a true boxer engine for that noise
@skinner_87
Finished my spring cutting and measuring etc and I have interesting results to note too.
I've managed to set H701s forest rally kit up perfectly. Using a method I've never before considered
I'll write it all up shortly
Yes and noSo 1.25 coils is the same as 40 mm springs? No progressive spring rate too so they should feel stiffer
