Get em replaced... but for the cost... save and get a decent setupJust wondering wether to do that for the mean time before I get a proper setup. The offside has sagged quite a bit, probably best to replace them all tbh
Hehe... research warsAlso JUST enough space below for electric water pump *grins*
Manifold is fitted to the 1.3 and sounds great! Can't wait to do the first rally of the year!
When did I say I was stopping? :O Yeah doing Pembrey in February, then putting the 1.0 back in to do Senior F1000 championship while a 1.4 engine is built ready for the end of the year!Thought you were stopping rallying? going into a 1400 class then?
1.4 will be for road rallies too yes hopefully!Thought you said a while back you were just going for road rallies? May see you around then
I'd of thought flow rate would be proportionate to rpm? As the pump spins faster with tge engineIf it helps, the flow rate in L/min is the displayed number divided by 5. Cruising at 30-40 mph I was getting about 1-2L/min, with hard high speed driving it went up to around 5-6L/min and hard low speed driving I got around 8L/min. It Idled at about 12L/min, but letting the engine idle until the flow rate maximised and red-lining the car showed about 30L/min, so I'm guessing thats the max flow rate of the coolant. Makes sense, you get less parasitic losses and better cooling capacity by reducing flow rate and increasing radiator size, at the cost of extra weight.
Yeah, which is why I let the car idle so the thermostat would open and then red-lined it to determine the maximum. The hard driving figures are what I saw just before changing upI'd of thought flow rate would be proportionate to rpm? As the pump spins faster with tge engine
Ah I see good stuffYeah, which is why I let the car idle so the thermostat would open and then red-lined it to determine the maximum. The hard driving figures are what I saw just before changing up
Almost convincing to convertWhat it does mean is that 80L/min the EWP80 puts out is WAY more than capable, and running it at less than 50% duty cycle even at the hottest time of year, the life of the motor should be way more than the 3000 hours they say for running flat out (no controller)
If you do what I'm doing and having it set to come on full whack when the fans kick in, it gives you some pretty silly cooling potential. Eliminating a pulley reduces rotational mass, and you reduce the risk of cavitation you get when you increase the maximum engine RPM without reducing the pulley ratio on the water pump to reduce pump speed.Almost convincing to convert
Though I've no reason to
Water pump is £25If you do what I'm doing and having it set to come on full whack when the fans kick in, it gives you some pretty silly cooling potential. Eliminating a pulley reduces rotational mass, and you reduce the risk of cavitation you get when you increase the maximum engine RPM without reducing the pulley ratio on the water pump to reduce pump speed.
It is £130 though...
you hav,nt heard mine in the flesh tho andy this camera mike does,nt do it justice.You'll never beat a true boxer engine for that noise
I'll hold you to ityou hav,nt heard mine in the flesh tho andy
makes it sound raspy/chavvy eh scottLaptop speakers don't do it justice
JAE then mate IF yours is finishedI'll hold you to it
its nice to have zero smoke and dry pistons for a change, all my 1.3/1.4,s seem to drink about half a pint of oil a month (and chuff smoke when pulling away in 2nd gear first thing in the morning).
found a humdinger boost leak tho ! the factory sealer has "blown" on the t/b cover, had to dremmel the black sealer off and araldite it down
FixedJAE then mate WHEN yours is finished
Fixed
Can't have a micra there sounding like a subaru engine without having one there actually with a proper boxer in eh
That meme made me chuckle
APPLY WATER TO THAT BURN!
LEEEEEAVVVEEE ITTTTT YEAHH!!!
That's how I picture Steves (@mcmicra) face when he says nissanubaruSome people say....
To the idea a nissubaru!!
#hatersgonnahate
juuust about hitting 5v when i bounce it off the limiter in 2nd@noddie the maf maxed out at 5.12v on the CGA, lets see if we can get a CG10 to that level too
So capable for cg10T then.juuust about hitting 5v when i bounce it off the limiter in 2nd
yes spot-on for a CG10 ed, dunno what psi it was tho (my gauge only goes to 10 psi) these CG10,s run so much sweeter at their limit than the other CG,s doSo capable for cg10T then.
With increased boost?
the short stroke alex, you get smaller bangs in the cylinders but more rpm tho eh.You mean they feel a bit more revvy?
How much more power do you reckon you've managed to squeeze out of it then?
Over 10! Wow.yes spot-on for a CG10 ed, dunno what psi it was tho (my gauge only goes to 10 psi) these CG10,s run so much sweeter at their limit than the other CG,s do
yes very undersquare like superbikes and the like eh ed (but with very tame cams) and the 1.3,s are just stroked 1.0,s.Over 10! Wow.
I'm guessing the engine was enlarged from the 1.0 so compromises were made...
