Ok just found why i cant, apparently i am not permitted to post attachments.. Possibly cause im only a forum member?
ddididdid u use air gun to spin it ?
Any chance we can go back to the old days with seperate threads please? my netbook hates this site and in particular this thread, I'm missing so much of what goes on in this mish-mash rubbish.
Please start a thread on just your build frank, you have 1 on CMF so why not here? This thread is good for info yes and all point put in one place but it's do busy with full in detailed build posts and "I washed my car today" posts, which not a bad thing on its own they shouldn't be lumped together in 1 thread like this![]()
Pepper
Nice one Frank, now get boosting!
You don't need a bov
Not unless your running 2bar boost
Sounds better without bov imo
guess thats your intake all sorted.![]()
pretty much kris
minor setback tho, the oildrain is too high up when using the crankcase breather (unless you have a topmount turbo) and its making the oil back up, and leak into the intake
so i,ll have to pull the sump tomorrow and fit a spout
Finished prepping & stripping the head prior to commencing headwork![]()
make with the pic,s then dave fwn
WDID: had an accident with the angle grinder
Is it faster now?
I got mine off a saab for a fiver. works fine.ooooooooooooooh yes (Y)
and i,ll do a vid when i can take it over 4k and/or WOT, i doubt if this 11.5:1 c/r engine will take full boost
damn loud chatter thogonna need a bov imo
Looking good man! whats the plan for mapping? megasquirt? try the engine temp plug trick ehmakes a massive difference, just dont run like that for more than a little blast or you will end up like me haha.
Lol sounds brutalis it detting its mars off?
It's upto you on bov but defo run it recirc if you can. Most modern turbo engines will have a plastic bosch recirc valve
Just so you know, my drift car has been running 14psi on stock turbo for 3years no trouble and the compressor wheel is ceramic![]()
ahh cheers kevand no sign of det yet
(tho i pulled the timing back to about tdc)
we,re back on full N/A atm (got it down to about 1/2hr mani change now lol)
so i will be able to race dave in the santa pod N/A category, and then race paul and mov 1/2 hr later (Y)
looking good mate. how did you sort out the oil issue you pointed out the other day?WDID ?
made it go "chatter chatter chatter" lol :laugh:
had to drill the sump george :doh: (the pic in post # 1426) i was hoping to avoid that sh###y job by using the crankcase breather, but the return pipe has to point downwards on these tubs else they piddle ot of the bearings.
going back to N/A has given me a chance to compare this CG t/b with the SR one
sorry frank i meant the oil flow
http://www.youtube.com/watch?v=Nn4_WryUfjs&feature=channel_video_title
seems too little
ahh gotchajust a combination of me pulling the pipe up on the vid, and also making it flowing uphill i guess mate, it probably flows a lot faster now its properly installed,
