lost countAnother Frank
How many engines/setups do you have
That one could prove interesting. Not heard of that idea beforelost countthats a 1.0 piston one, then next on the list is the stepped/machined piston/CGA crank one
i had to use 2 headgaskets last time andy (because the 1.0 pistons protrude out the block if you use a CGA crank) so we shaved a bit off the crowns on a lathe, to clear the quench steps insteadThat one could prove interesting. Not heard of that idea before![]()
Ah right I see. So 1 h/g this time? Should see a raise in compression theni had to use 2 headgaskets last time andy (because the 1.0 pistons protrude out the block if you use a CGA crank) so we shaved a bit off the crowns on a lathe, to clear the quench steps instead
ayeAh right I see. So 1 h/g this time? Should see a raise in compression then![]()
Keep us posted Frank. Interested to see your results
Longer studs and proper nuts for alloy wheels needed...Have problem with the rears though, don't sit on the bolts properly, fronts are fine, rears don't seem to go on all the way - only half the nut gripping ?????![]()
Pfft neverproper nuts for alloy wheels needed...
YupHehe have I started a revolution
Good news
What does Pfft mean ?????Pfft never
Don't forget to bring yer hammerGood news![]()
Its a noise people make when they dont agreeWhat does Pfft mean ?????
I'll bring 2 and a chiselDon't forget to bring yer hammer![]()
Sounds familiar.....I hope for your safety you're not driving around like that, if they're mazda wheels the centre bore is too small
I'll name that in twoI'll bring 2 and a chisel
Maybe they have spigot ringsThe wheels fit properly on the front (full bolt) but on the back that raised bit on the back of the drum cover looks to be the problem - or just get longer nuts ???? bolts even ha, ha.
Ermmmm!!! yes I'm driving around like thatSounds familiar.....
Ha !!! never looked at that (dopey again) maybe, I'll let the garage geezer have a look tomoz (text speakMaybe they have spigot rings
Ermmmm!!! yes I'm driving around like thatI'll take it to the tyre place tomoz (that's text speak
But I caught at least half a thread ................................................... only joking, I know it is not safe - thanks for your concern budYou need longer wheel studs and at least a 5mm spacer, if I was you I'd swap back to standard wheels before something happens
Whip wheel off. Pull plastic ring out. Easy![]()
Tomoz init
Oh yeah... final instruction... put wheel back on
Ah I remember that... you into the habit of checking every time you get in the car?And tighten wheel nuts, this is essential (as I'd know)
They could drill the centre of the wheel out to fit over it ?????Noo the ridge wont go anywhere![]()
Oh the wheel... yea can get that doneThey could drill the centre of the wheel out to fit over it ?????
HAH HA - got it, the spacer will lift the wheel out past the ridge, cheers bud, I'll need longer bolts then, I'll get that sorted.If you were to do that, best take it to a machine shop.
Although Mas told me the other day that a 3mm spacer would work as it would remove the CB problem?
Not with 3mn you wont![]()
