Originally posted by quickdraw
to be able to replace the original existing side repeators/indicators for new clear/smoked/modified side repeators, copy as follows:
1: gently twist the side repeator anti-clockwise (this may have been stuck down, so gently increase pressure untill movement
2
nce indecator has turned this should pull straight towards you and away from the wing
3: pull cable all the way out until you reach the connection block, remove this from the hole aswell..
depending on which style of side repeator you have purchased this may be as follows:
for repeators with similar connection block
1: unclip the connection block from old existing repeator and replace with new repeator
2: re-place the indecator into its correct position making sure all cable is tucked back in.
(slight body work may be required or the use of a sticky pad may be required for this stage.
for repeators that dont have connection block
1: using a pair of wire snips and wire strippers cut the existing cable shielding at a conveniant length and srtrip to bare cable
2: strip the new cable shielding back to bare cable
3: connect the corrosponding cables together using sufficiant means I.E. connection blocks
4: re-place the new repeator and cabling back intot the existing hole, again slight body work or the use of a sticky pad may be required
test the repeators before making a journey
