Fixed water pump :grinning: all that's was needed was a new gasket :laugh:
heh true did you get a new water pump then? least you can be sure itll last a while dude!
i cleaned my car today, thats what i did![]()
Looks a little lonely there
Finally replaced my filthy air filter. Anyone know if an abnormally dirty filter could cause the same symptoms as having an overly rich fuel mixture?
knocked up another hybrid clutch assy (half 1.0 and half 1.3) because the little 160mm ones will only transmit upto 100hp, and the previous hybrid one that i fitted a few days ago is slightly rubbing against the cover when the clutch is down fwn
Have you got more info on this clutch? Are you using cg10 box and flywheel?
Could I make one to fit my car? I have a feeling my clutch will poop itself when I finish the hi compression motor and have it tuned!
Although is it better to destroy clutches so that the boxes survive better? The are about same price lol
lol, i cheat martin :wasntme: i have no brackets from the sump to the g/box (just the 4 bellhousing bolts) and no bracket under the inlet mani (so i dont have to unpick the alt and earths loom) the battery is next to the ecu (relocated) the starter motor and clutch cable are left on, the bumper is a 2 minute remove, the front mount is removed :grinning:Dammit Frank! Just went I thought I was getting closer to your time! How on earth do you remove it in 39 mins
