manifold, turbo, i/c piping, intercooler, dump valve, oil feed, oil return, bigger injectors, fuel pressure regulator, bigger fuel pump, forged internals if you want more boost lol and it will fit as the cg10 and cg13 are the same fitment...id recommend spending the money on a cg13 before you turbo it, will be better in the long run stani
if your getting another engine to do the turbo build get a cg13de auto block as they are stronger. altough you would need a normal cg13 manual gearbox inc flywheel etc.
altough if turboing a cg10 you can use the cg13's pistons as they are dished and lower the compresion over the cg10 flat pistons...
Yeah get the CG13, there was a brand new kit on ebay not long ago for £1300 iirc, that was a bolt on thing, but still needed a few bits and bobs...wonder who bought it? :suspect:
yeh but then the piston doesnt come as far down cause of the throw on the cg10 crank and then that means building a bottom end if u want to change piston heads, just buy a cg13 and fit it, time and money saved and faster!
