Barker said:Curbed one of them to fvck earlier, nearly cried im not even joking. Horrible noise.
Tyre walls saves wheels
Barker said:Is there anywhere else other than Matt Humprhies i can get 50mm springs?
£160 is a bit steep for me
Matt humphries it is thenAfraid not unless you want coilovers but I'd say they're out of the question
Ring him or pop round to his micra emporium
skymera said:try and get them welded so the springs can't pop out the cups.
don't follow this advise, if you need to secure springs into their cups then wire them in. Heating them up can have adverse affects on the springs
100mm is where the bumpstops make contact, you would be constantly sitting on them with only 1/2 a spring (and the springs were doing sweet FA) hence the hard rideI had my rear springs cut clean down the middle so 1 rear spring became 2 which I use for each side, and it got me down about 100mm+ but ride was awful, wouldn't recommend it.
Well i paid £30 and i've never posted anything before so you'd have to bare with me but £25 posted? Depending on how much itll be like
ok,if youve still got them come payday ill take them for £25 posted.it will be in a couple of weeks.
Went to the scrappy today and came back with a front offside wing in red, an almera airbox, and a number in my phonebook for a lad thats buying my micra alloys tomorrow for £100 plus his steelies. Met him and his mate there, they were looking at the same micra and they helped me get the wing off, two very decent lads, one of them is building a pre-facelift 1.0L for track use.
Not sure wether to whack the wing on while ite red or try spray it/get it sprayed. Also not sure about whacking hte airbox on, it sounds simple but i bet in reality when i go to do it it's not.
Are those guys on here somewhere? Mines a 1L so i wanna see what they can get out of it!
Which year/engine almera did u get the airbox off? Was considering a similar airflow upgrade for mine, maybe a bigger throttlebody too
Sounds like you got a good deal on the wheels![]()
Does it make much of a difference?I assume your disconnecting the breather from the airbox not the other end right?
Im talking about the small pipe that comes from the corner of the valve cover and into the airboxWell when u lift off the airbox theres the breather pipe coming out of the bottom of it and its easy to disconnect there, the other end of it i never traced but i would think its more solidly fixed as the airbox is more often meant to be fiddled with. give the airbox a twist off and you'll find theres the rubber breather pipe still holding it, just putt it iff and you have the bare throttlebody and the breather you can lodge between your HT leads while u work
alrite fella....got some brand new tein 35mm lowering springs still in box corsa b g max uprated rear shocks n a janspeed strut brace if ur interested??Right cant buy the springs, just rang Matt Humphries up and the price of the 50mm springs is over £200 and im not paying that. I told him on the price list it said £157 and he said the prices have been updates March 2012. One problem after another.
green also got a set of nissan 13" alloys springs shocks n strut brace posted for £150 £60 for alloys no tyres..What colour are those tein springs? Also what kinda price? I wanna lower but cant afford it on insurance lol so if i do it needs to be subtle!
