SirChris
Educated Bodger
Opinions on them mate?get electrical joiner crimps and use copex where the wires have to be exposed to the elements
Sent from my iPad using Tapatalk HD
U suggesting a method here Ed. Wat would you get from hereThese people don't mess about, about as good as electrical components get. http://raychem.te.com/
That's not what St. Cross taught me but you may be rightSolder only becomes brittle if if its a solid object soldered to a solid object and there is vibration, for wires there is more than enough flex to take out any stress that would be transfered to the wires. At Rolls we only use crimps when we can't get a soldering iron to the work or vice versa. Soldering guarantees better conductivity too, and poorly crimping high current wires is a fire hazard.
For removable stuff just reuse the oem plugs etc, just leave enough cable on them if you have to chop em out that you can resolder it all up.
Go to a scrappy and nick merc or audi etc connectors
Sounds like you need more fibre...Continuous runs ftw eh?
-oo-my key-oards -roke ,,,,,,,,,,,,,,,,,,2 letters are go-e,,,,,,,guess which o-es![]()
This is my prefered emethod and never really caused any issues, i tend to use tank tape wrapped around the outside to give strength. Has the advantage that redo or reworking wiring on an event is much easier. On the London Rally i had to redo the connections to the ns headlight, if they had been soldered then this would have been a lot harder and taken a lot longer, was luckily in service so no time pressures but if on event properly all time lost would have been......I use the twist, fold and insulation tape. Never failed.
But other than that I agree with ed. Decent crimpers and heatshrink wins
been on holiday mate starting soon.yo little's hows the pro gress going?![]()
okay so maybe twisting of both ends together with tiny bit of solder at tip with some decent tape. I worry about snags breaking them apart.This is my prefered emethod and never really caused any issues, i tend to use tank tape wrapped around the outside to give strength. Has the advantage that redo or reworking wiring on an event is much easier. On the London Rally i had to redo the connections to the ns headlight, if they had been soldered then this would have been a lot harder and taken a lot longer, was luckily in service so no time pressures but if on event properly all time lost would have been......
Hve had soldered, crimped and taped up joints fail on rally cars, probably crimped stuff is the worse for failing.
I only solder deep in loom repairs and then with leaded solder only.
Yeah will help us get high whilst painting eh?yo,,,,,,,,,,,he is still alive ! . no extraction in the spray room should help you out![]()
