hey all, bought an aftermarket tacho and wandering if anyone knows a good place in birmingham to get it fitted?or if anyone offers the service on here? cheers
agilecanon said:you know what,gonna try it myself....how hard can it be lol, could someone just clarify if these wires would be o.k to use to extend the tacho wires,as the tacho wires are only about 6 inches longand about 1mm in thickness http://www.halfords.com/webapp/wcs/..._productId_201167_langId_-1_categoryId_265892 muchos grazias
you just need to get some wire that is the same gauge or bigger than the ones on the tacho ehyou know what,gonna try it myself....how hard can it be lol, could someone just clarify if these wires would be o.k to use to extend the tacho wires,as the tacho wires are only about 6 inches longand about 1mm in thickness http://www.halfords.com/webapp/wcs/..._productId_201167_langId_-1_categoryId_265892 muchos grazias
Do you need specific wire?
I just bought the cheapest wire in Maplin and it worked
http://www.maplin.co.uk/equipment-wire-24-0.2-6198i just look up on Maplin so its got so many wires.... do you know which one is it?
Sorry to highjack this and please excuse my ignorance.you just need to get some wire that is the same gauge or bigger than the ones on the tacho ehand you can tap into the blue wire on the smaller connector to the dizzy
my mouth hurts from holding the torch
agilecanon said:thanks guy, but i used these http://www.halfords.com/webapp/wcs/..._productId_180127_langId_-1_categoryId_255229 makes life alot easierjust needing to know how to connect the signal wire to the dizzy,as there is not enough room on the blue wire coming from the dizzy to use one of the connectors,anyone?
