Speedle said:from what ed told me a while back and IIRC the super charger runs up first and then the turbo takes over for the rest of the rev range so only one runs at a time, its all controlled by the onboard ECU
Ian said:hmm, what i said was not swear evasion really... plus im pretty sure it was the first time i did it, and how many kids browse this forum?
Craig said:I was having a little think aboutit you will only need 1 dump valve, as close to thethrottlebody as possible and the air would be switched between the two by just closing the valve to the inlet of the supercharger
Ed said:No this is not needed this way at all. Rethink it into one system dont treat them as two! If it helps to some searching for the Lancia Delta S4. That and the March ST are very similar, in overall design, although the ST is much more refined.
Ed
Ed said:Incorrect you most definately DO want them both working in the same system and pipe work as I said be patient im not going to write it all twice lol. Turbo comes first as well... THEN the supercharger. Its without doubt the best way to do it as I shall show later
pietro said:Ed any luck on this article? Would be great to read!
Ed said:Your looking at a week or so at best, before I have done this.
umm i do intend to finish it i may dig it out and start again on it soon.
I understand how it all works on the st because I owned one for the last 2 years, but don't have the proper english to explain lol.
Thats fine, appears I'm not too bad at understanding your irish!
That picture is a perfect description!
