i,ve got some CGA mani,s (topfeed injectors) stani (complete)
if its an option ?
does anyone know what injectors james/nis is running and how they were mounted?
anyways stani the 1.6 injectors are fine to use, i would only look into changeing them when they hit about 80% dutey cycle.
if its an option ?
You'll hit 80% very quickly.......I'm in the low 70% range on GA16DE injectors on my NA setup.
I have Davey C's custom rail..
Had big problems with it at the weekend.. badly made.
However I have since got a Fabricators to make a Jig, for Custom rails.. They are sleeved on a Jig and the Injector 'Cups' are Straight planed so they are as good a fit as it gets.
I can supply these with either 256cc or 370cc injectors.. Direct for for CG10 / CG10
From Plumbing to mounts to Wiring! all direct.
These are tested.
