yep as above there should be a small insert filter on the inside so all shoule be well, pic of the filter on
I don't get these? What difference is there to the conventional tube?
well according to what ive read it stops oil fumes going into the airpain and being reburnt again which in turn can damage seals?
please correct me if im wrong
Sounds sensible to me .
Modern car engines are designed to return the crankcase fumes back into the engine normally via the air intake system and into the inlet manifold. The problem with this is that oily fumes can contaminate the air-fuel mixture causing the car to run poorly. This can also lead to high fuel and oil consumption and smoky exhausts.
http://www.crankcasefilters.com/
I havnt ever read soo much bull#### in my life! The only time you get oil coming out of the hole is if you fill the engine upto the cap with oil, or your piston rings are that shagged that your crankcase is being pressurised.
damage seals? As in the valve stem seals? But as you asked, you are wrong. Never believe a website's information if they are trying to sell you something. Now in a perfect world we want our engines to be constantly fed with cold air, so removing this pipe stops warm air thats been circulating around the engine entering but the ammount is that small you wont notice the difference.
The only reason you put a filter on there is when you put a performance airfilter on so you havnt got the original air pan to connect the pipe to.
