Antony: Yeah, I've had a look at more modern s/c of similar size and there are a few that could give a little more boost, be better equipped for higher hp and put less load on the engine. I think its a way of developing the engine that has great potential tbh. The stock turbo is capable of running as much boost as you could safely run so not really necessary to upgrade unless engine is built tough enough to put booste up much higher.
Apparently it is easy enough to put a magnetic clutch in to disengage the s/c manually.
Baz: If I'm reading that right then I think you would have a kaboom on your hands... Ok, I dont know much about MA series engines beyond the ma09 but I just mentioned the ma10 coz I knew it would definitely be interchangeble with it.
Look at this and compare the compressions, torque at rev ranges and then take into account the ma10et and ma09ert are the only ones with the additional compression from forced induction.
http://en.wikipedia.org/wiki/Nissan_MA_engine#MA09ERT
Ok so if you had a ma12 head, with 7.7:1 with 1.4-1.5 bar I dont see how it could possibly survive for very long, it just wasnt built for it (note it runs with lower compression than a na ma10). I think if you were to go into minor detail to try and build a really tough hybrid you would possibly rebuild with a ma09 head and ma12 bottom half with custom internals...I dont know enough about ma engines to know if the ma12 bottom half would be viable though, i was just speculating. So by having a smaller bore on your head you have a more bulletproof head that can withstand a higher total internal compression, push to higher rev ranges and have the car in peak torque range more of the time.
